Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 4 of 13 <123 45 ... 111213>
ebajema
Ibartsimp wrote:
Ok, they are such good specialists that even the Range knew it Laughing
The boss put the key in the barrel and the car started immediatly (so he just told me on the phone)!
So he tells me that RRs can be bothered by interferences from TV antenas (the ones that broadcast) and it's true that my village has a big one... and sometimes moving just some hundred meters solves the issue.
Ever heard that?
He will now investigate on the battery drain. Will keep u posted.
I HATE that when a car does that. You can't get it to work, try everything nothing works, get help and the bloody problem seems gone !!! AAAARGH. Well I hope that at least they sort out all your small issues as well as the big one (current drain) and lets hope they can do something about the RFI (Radio Frequency Interference).
It might pay to get all your ground points cleaned and "Vaselined" as good grounding can help in avoiding RFI problems (although in vessels/ships there are two "schools" the ones that tie the RFI cable shielding to ground and the ones that don't). MY 2010 5.0 SC Galway green and sand interior!!
Post #164707 14th Jan 2013 6:39pm
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Thx, how are the ground points identified?
Reg the FSR, is there a test to know it's dead?
Post #164747 14th Jan 2013 7:50pm
Earth points: all brown wires, usually many together at these points:
Re: FSR
No way to test that I am aware of, but symptoms are: battery drain, no fans, or fans all the time, or a combination Sad .
Post #164944 15th Jan 2013 3:55pm
Ibartsimp
Hi Joe, thx for the info. I'll check that. Reg the FSR, the only, maybe apparent symptom is battery drain.
News of the day : the car wasn't used at all yesterday and started like a charm this afternoon (at the garage). They will make alternator tests & others on thursday.
Post #165001 15th Jan 2013 6:36pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
When my FSR went it was so hot after the car was parked for 4 hours it burned my technician, surprised the car didnt catch fire. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165003 15th Jan 2013 6:42pm
A way to test an FSR is to install an ammeter in the battery earth cable and measure the current drain after the car has gone to sleep and then do the same again having removed fuses 34 and 64.
The difference in the currents measured is the battery current drain thro the FSR.
If it's anything more than a few mA, you need a new FSR.
In operation FSR's generate a considerable amount of heat, hence the cooling rods attached to them. The heat is disipated thro the cooling rods into the inlet air stream for the ac blower fan.
If you operate an FSR without adequate cooling the body and fins will heat up to a temperature easily capable of causing a serious skin burn if held, not recommended.
I've come across them in other vehicles protected by thermal fuse's rated at 220C and seen them burn the thermal fuse out.
Post #165022 15th Jan 2013 7:04pm
Ibartsimp
Thanks a lot for the info, I'll pass it to the garage (just in case)
Post #165107 16th Jan 2013 8:07am
Ibartsimp
Here's the update : got my car back today, and guess what, everything is ok (and has been for the full week). The test bookd didn't give anything
I will carefully look what's happening in the coming days and tell you and conduct the suggested tests when I have time.
Also, I was wondering if the fact that I parked it on a non flat area could consume battery during the night (with susp trying to compensate) ?
Post #165688 18th Jan 2013 2:39pm
Ibartsimp
Flat battery again this morning Sad grrr
Post #165857 19th Jan 2013 9:54am
Ibartsimp
tested it, 11.2v, does it mean it's definitely dead? or just that it needs to be recharged?
I still have to restart it to test (again, just in case) that the alternator is operating properly
Post #165866 19th Jan 2013 11:04am
No it's not dead just needs recharged. Thumbs Up
The air suspension shouldn't affect anything, unless of course the compressor relay is sticking in the on position.
Post #165870 19th Jan 2013 11:28am
Ibartsimp
Ok, battery charged, battery is delivering only 14v whatever the rpms (2000, 3000), measured at the positive & negative battery terminations.
Tested on my fathers' 530d, it delivers 14.6.
Next ill do the tests mentioned above.
Wdyt
Post #166095 20th Jan 2013 3:04pm
Ibartsimp
From battery earth to what please?
Post #166098 20th Jan 2013 3:11pm
JohnnyDangerous
If the battery is fully charged then thats about the same as mine. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #166101 20th Jan 2013 3:12pm
Ibartsimp
ok, thx
@nicedayforit, can you give me more precisions about how to test the fsr (see above)?
Thanks
Post #166210 21st Jan 2013 8:46am
