![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Thx, how are the ground points identified?
Earth points: all brown wires, usually many together at these points:
Hi Joe, thx for the info. I'll check that. Reg the FSR, the only, maybe apparent symptom is battery drain.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
When my FSR went it was so hot after the car was parked for 4 hours it burned my technician, surprised the car didnt catch fire. One day your life will flash before your eyes......................................make sure yours is worth watching!
A way to test an FSR is to install an ammeter in the battery earth cable and measure the current drain after the car has gone to sleep and then do the same again having removed fuses 34 and 64.
Thanks a lot for the info, I'll pass it to the garage (just in case) |
Here's the update : got my car back today, and guess what, everything is ok (and has been for the full week). The test bookd didn't give anything
Flat battery again this morning |
tested it, 11.2v, does it mean it's definitely dead? or just that it needs to be recharged?
No it's not dead just needs recharged. |
Ok, battery charged, battery is delivering only 14v whatever the rpms (2000, 3000), measured at the positive & negative battery terminations.
From battery earth to what please? |
If the battery is fully charged then thats about the same as mine. One day your life will flash before your eyes......................................make sure yours is worth watching!
ok, thx
