![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
When my FSR went it was so hot after being parked for about 3 hours it burned my guys hand !!!! so if you can get near it and its hot after the cars been switched off a while thats your problem. One day your life will flash before your eyes......................................make sure yours is worth watching!
Ibartsimp Member Since: 24 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Connections are and were tight
You could check the cables from the alternator for resistance. One day your life will flash before your eyes......................................make sure yours is worth watching!
So after several investigations, battery's not the issue, resorting to this (direction LR Approved garage)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
still looks good even on the back of a low loader... |
Did you check the FSR ??? One day your life will flash before your eyes......................................make sure yours is worth watching!
No, didn't check the FSR (I didn't know what it was but I have now done a search and see). Will point that to the indy.
Youve not had a lot of luck have you ??? One day your life will flash before your eyes......................................make sure yours is worth watching!
Has it gone to a RR specialist as TBH now ive had one for a couple of years even a very good garage will struggle with the intracasies of a FFRR unless they have experience. One day your life will flash before your eyes......................................make sure yours is worth watching!
They are LR specialists, not RR... If he proves not to be competent, wil go to the dealer (there are 2 in my area) |
Ok, they are such good specialists that even the Range knew it |
I thought that was the P38, that was quite commom on those. One day your life will flash before your eyes......................................make sure yours is worth watching!
Now that you say it, I think I remember the same guy telling me the same thing about my P38 (I've had 5 btw |
What about the current drain? One day your life will flash before your eyes......................................make sure yours is worth watching!
