![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Mike - my thread will be using the Disco 2 bottle jack for roadside and SGS 3 tonne and adaptor for home work |
Has anyone found a 'pad' that can be put on the bottle jack to make it L405 compatible (not used it since having L322s ans it's a waste)?
Pad has arrived. Feedback shortly in a new “DrRob jacking thread”
2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Just a tip Rob, but make sure not to let the piston drop whilst you have got the saddle removed
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Mike. Thanks. This adaptor is for using with my trolley jack. Pad to pad if that makes sense. I have a Disco 2 bottle jack for roadside wheel changing under the lower suspension arms |
The pad fits perfectly in the sill slot |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Anyone any thoughts on whether this would fit?
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
It'll fit the car, you need to mod it to fit the jack Current: 2011 FFRR Vogue SE 4.4 TDV8
You don’t. need to drill it all the way through, just deep enough to get the pin back in.
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 184 ![]() ![]() ![]() |
Has anybody found a good place to buy a jack they all seem expensive on eBay |
Ok, my jack arrived the other day. £34.99 off eBay, brand new inc delivery. Rather than order the metal top a lot have done,
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
I found this in the back of our workshop today, a Weber Hydraulik 5 Ton bottle jack, I am going to file the ends off to have a flat surface and cut a 30mm x 55mm alloy rectangle 11mm thick or so, and weld it on for my L322
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
I've just purchased a brand new 2 stage 2T bottle jack on ebay for £40+ postage - as I couldn't find a Sprinter jack at a reasonable price.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Duplicate deleted by author |
