Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module
Page 1 of 7 1234567>
Budgie
I'm trying to retrofit a Bluetooth ULF Module in a 2003 4.4 Vogue.
I got a second generation BMW module with part number 84 21 6 938610 and fitted it this morning.
I have the wiring loom factory fitted, although I seem to be lacking something for the white/purple end of the aerial lead to plug into.
Aside from the aerial, when I plug the connector into the module it blows the 7.5amp fuse (number 22 I think it is) for the telephone in the glove box fuse box. Also, when the connector is in place, all the audio systems shut down. As soon as I disconnect from the module the audio system, including the main screen, comes back to life so I know something ain't right there.
So questions:
1. Has anyone seen anything like this and may be able to point me in the right direct of where to look.
2. Could it just be a duff ULF Module and is there a way to check?
3. Where does the white/purple antenna connection plug into?
Thanks in advance.
Martin.
Post #146654 16th Oct 2012 10:35pm
daveo
STOP.... Shocked you will do big damage to the module and poss to the cars electric, you cant just plug the bmw ulf module in...your wiring loom has to be re-pinned, the telephone loom in your car is not ment for the bmw module even know the plug will goe in, i dont have the re-pin chart to hand but its not hard just critical...do a serch,some one may have it on here.. V8 facelift Range Rover Autobiography 22" wheels.
Post #146655 16th Oct 2012 10:58pm
Budgie
Thanks Daveo,
Once the fuse blew I removed the the connector until I could do some research on it. Thumbs Up
I'm having a scan around the other bluetooth related threads but now I know what I'm looking for. Mr. Green
If anyone has the re-pin chart then it'll be handy but I'm off for a search.
Post #146657 16th Oct 2012 11:11pm
SteveMFr
Site Sponsor
Search for the site l322.com in the internet archive (wayback machine). You can still access the re-pin chart there.
Nothing ever disappears completely once it's published in the internet... Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #146680 17th Oct 2012 8:09am
mjdronfield
If you come unstuck, I've already done this mod, have a search on here for my threads.
PM me if you need any more info or you can't get the repin chart.......
http://www.fullfatrr.com/forum/topic9811.html?highlight=bluetooth
http://www.fullfatrr.com/forum/topic9813.html?highlight=bluetooth
http://www.fullfatrr.com/forum/topic9678.html?highlight=bluetooth
http://www.fullfatrr.com/forum/topic9783.html?highlight=bluetooth
http://www.fullfatrr.com/forum/topic9652.html?highlight=bluetooth
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #146697 17th Oct 2012 10:00am
Budgie
I found the re-pin chart in one of Marks threads, just need to dig out the electrical manual to make sure I've got the right pin numbering.
Steve, do you have a link at all to the l322.com archive? I searched on Google but found nothing.
It also looks like I need the antenna as I can't find one in the rear of the FF. Wink
Post #146741 17th Oct 2012 3:01pm
mjdronfield
The pin numbers are on the actual connector body when you take it apart.
The blue connector slides apart to give 3 single rows so you can see the pin numbers......
If you get the new connector from an Audi dealer, it is much easier, as all you have to do is remove the wire you want from the connector on the car, and put in the correct "new" place in the Audi plug, using the re-pin chart as reference.
When you are done, plug the audi part into the cars loom.
The old unused connections will be left isolated in the old connector.
I got the L322.com bit from the web archiver, but would have managed OK without. All you need is the repin chart and the info on the threads anbout ground connection and similating the pairing button.
Job done.
I thought there would be soldering required, but there is not.
With a really small flat blade screwdriver and some care, you can press the tab down on each wire connector, and gently remove from the connector intact. Thumbs Up
I hope you have not blown your ULF unit when you plugged it in the car, but I feel you may have........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #146742 17th Oct 2012 3:34pm
Baris
I do retrofit looms for the Bluetooth, if anyone is interested.
Post #147220 20th Oct 2012 3:45pm
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
How much baris?
Post #147323 21st Oct 2012 6:50pm
Baris
Deasy wrote:
How much baris?
Can do them for £110 + £10 postage. You will need the bluetooth ulf, bluetooth receiver, and a microphone.
Post #147344 21st Oct 2012 8:18pm
Budgie
Just resurrecting this thread again as I finally got around to re-wiring the plug and fitting the antenna, mic should be here tomorrow.
Sadly it looks like I did blow something in the ULF box when I plugged it into the original wiring.
Just to check, I re-wired the plug as per this guide, I take it that's the correct one?
http://www.fullfatrr.com/gallery/albums/us...Pinout.pdf
On the screen the "Telephone" button is white but when I click on it the button depresses and then just stays there. Also the fixed red light is on at the top of the screen, meaning "Connection not possible". So I assume it's a duff ULF box?
I'm going to have a look around the Bay or E this evening an try to get a newer one that the 3rd generation one I've got now but any advice is welcome. Mr. Green
Post #186858 6th May 2013 6:54pm
mjdronfield
I've a feeling you aren't the first or the last to plug a ULF in without doing the rewire first.
When I did mine, if you got Telephone on the screen, it proved there was power and earth, and that the ULF was being seen on the ibus.
Nothing else happened until it was paired with a phone, and the aerial and mic etc were on.
Having the red light on doesn't seem normal at this stage.
When I pressed Telephone on the screen, it came up "Activate Phone", as it was trying to pair with the previous ULF owners mobile.........
Hope its of some use.
I'd try and substitute the unit if you can.......
Failing that, you may have to source another.
Think its either version 5 or 6 that allows Voice Recognition.
It will have "MIT SES" on the label.......
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #187071 7th May 2013 4:57pm
RichardP
Have you paired your phone?
-With the ignition off, press and hold the pairing button on the cradle (not the wheel).
-Hold for 5 seconds, then turn the ignition to the accessory position, the monitor should say 'Bluetooth Pairing' and the small LEDs on the monitor will flash.
- On your phone, search for bluetooth devices, select the BMW one and enter the 4 digit pin that is on the part number sticker of the ULF.
- You should hear a beep and see 'Pairing successful' or some such.
- Cycle the ignition to exit pairing mode, see if your phone connects.
Post #187072 7th May 2013 4:57pm
Budgie
I had another look today.
I tried pairing but nothing happens, when I turn the ignition to the first position I just get the normal screen, including the telephone button and fixed red light.
I do have a question about the wiring: when I did mine the wire in position 2 on the original, which is now in position 32 for the pairing, is white but the chart says it should be red/yellow.
When I connect the pairing wires, turn the ignition on and then disconnect the wires after a couple of seconds, I hear a "click" from one or more of the audio speakers in the car. I don't think this is correct and I'm wondering if I've got something mixed up while changing the connections?
The connections I've ended up with are as follow:
1 - White - was in 54
11 - Green - was in 38
15 - White/Grey/Yellow - was in 13
17 - Red/Yellow - was in 25
19 - Brown/White - was in 52
21 - Black - was in 53
32 - White - was in 2 (Pairing)
33 - White/Green - was in 47
35 - Violet/White - was in 12
36 - Brown/Black - was in 34 (Pairing)
37 - Black/White - was in 18
38 - Brown/Black - was in 17
51 - White/Brown - was in 29
Can anyone with a 2003 Vogue confirm that this is correct, or list what you've used?
Thanks for the info so far. Thumbs Up
Post #187105 7th May 2013 8:07pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I wrote the pinout chart you linked to in a previous post and if you have followed those correctly it should work fine. I did this to two different vehicles without issue.
As already mentioned the fact that the telephone option is now white and not grey or even missing denotes that the ibus recognises that there is a ULF/telephone module connected. As nothing happens when you select it I think there is every possibility you have fried your ULF! Shocked
In searching for a replacement I suggest a Gen 6 or newer but if you want the latest smart phones to transfer the phone book you really need to hold out for a Gen 13. Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #187119 7th May 2013 9:13pm
