![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I'm trying to retrofit a Bluetooth ULF Module in a 2003 4.4 Vogue.
Thanks Daveo,
Search for the site l322.com in the internet archive (wayback machine). You can still access the re-pin chart there.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7903 ![]() ![]() ![]() |
If you come unstuck, I've already done this mod, have a search on here for my threads.
I found the re-pin chart in one of Marks threads, just need to dig out the electrical manual to make sure I've got the right pin numbering.
The pin numbers are on the actual connector body when you take it apart.
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
I do retrofit looms for the Bluetooth, if anyone is interested. |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
How much baris? |
Can do them for £110 + £10 postage. You will need the bluetooth ulf, bluetooth receiver, and a microphone. |
Just resurrecting this thread again as I finally got around to re-wiring the plug and fitting the antenna, mic should be here tomorrow.
I've a feeling you aren't the first or the last to plug a ULF in without doing the rewire first.
RichardP Member Since: 14 Mar 2012 Location: North Yorkshire Posts: 16 ![]() |
Have you paired your phone?
I had another look today.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I wrote the pinout chart you linked to in a previous post and if you have followed those correctly it should work fine. I did this to two different vehicles without issue.
