![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I'm trying to retrofit a Bluetooth ULF Module in a 2003 4.4 Vogue.
Thanks Daveo,
Search for the site l322.com in the internet archive (wayback machine). You can still access the re-pin chart there.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7898 ![]() ![]() ![]() |
If you come unstuck, I've already done this mod, have a search on here for my threads.
I found the re-pin chart in one of Marks threads, just need to dig out the electrical manual to make sure I've got the right pin numbering.
The pin numbers are on the actual connector body when you take it apart.
If you get the new connector from an Audi dealer, it is much easier, as all you have to do is remove the wire you want from the connector on the car, and put in the correct "new" place in the Audi plug, using the re-pin chart as reference. When you are done, plug the audi part into the cars loom. The old unused connections will be left isolated in the old connector. I got the L322.com bit from the web archiver, but would have managed OK without. All you need is the repin chart and the info on the threads anbout ground connection and similating the pairing button. Job done. I thought there would be soldering required, but there is not. With a really small flat blade screwdriver and some care, you can press the tab down on each wire connector, and gently remove from the connector intact. ![]() I hope you have not blown your ULF unit when you plugged it in the car, but I feel you may have........ Mark 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
I do retrofit looms for the Bluetooth, if anyone is interested. |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
How much baris? |
Can do them for �110 + �10 postage. You will need the bluetooth ulf, bluetooth receiver, and a microphone. |
Just resurrecting this thread again as I finally got around to re-wiring the plug and fitting the antenna, mic should be here tomorrow.
I've a feeling you aren't the first or the last to plug a ULF in without doing the rewire first.
RichardP Member Since: 14 Mar 2012 Location: North Yorkshire Posts: 16 ![]() |
Have you paired your phone?
I had another look today.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I wrote the pinout chart you linked to in a previous post and if you have followed those correctly it should work fine. I did this to two different vehicles without issue.
