Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I'm trying to retrofit a Bluetooth ULF Module in a 2003 4.4 Vogue.
16th Oct 2012 10:35pm |
Thanks Daveo,
16th Oct 2012 11:11pm |
Search for the site l322.com in the internet archive (wayback machine). You can still access the re-pin chart there.
17th Oct 2012 8:09am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
If you come unstuck, I've already done this mod, have a search on here for my threads.
17th Oct 2012 10:00am |
I found the re-pin chart in one of Marks threads, just need to dig out the electrical manual to make sure I've got the right pin numbering.
17th Oct 2012 3:01pm |
The pin numbers are on the actual connector body when you take it apart.
17th Oct 2012 3:34pm |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 |
I do retrofit looms for the Bluetooth, if anyone is interested. |
20th Oct 2012 3:45pm |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
How much baris? |
21st Oct 2012 6:50pm |
Can do them for £110 + £10 postage. You will need the bluetooth ulf, bluetooth receiver, and a microphone. |
21st Oct 2012 8:18pm |
Just resurrecting this thread again as I finally got around to re-wiring the plug and fitting the antenna, mic should be here tomorrow.
6th May 2013 6:54pm |
I've a feeling you aren't the first or the last to plug a ULF in without doing the rewire first.
7th May 2013 4:57pm |
RichardP Member Since: 14 Mar 2012 Location: North Yorkshire Posts: 16 |
Have you paired your phone?
I had another look today.
7th May 2013 8:07pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
I wrote the pinout chart you linked to in a previous post and if you have followed those correctly it should work fine. I did this to two different vehicles without issue.
7th May 2013 9:13pm |
