![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
You will need the antenna to pair, as the ULF will not have a bluetooth signal otherwise.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I've just been and collected the antenna, cable and microphone from my local bmw dealers.
Cheers Andy. I re-pinned it slightly to correspond with your chart- I think two wires were different to the chart I originally followed from L322.com.
The last bit of the pairing procedure states to turn ignition off.
I know nothing about Navcoder. For example, how do you connect to the vehicle? |
Sorry, I'm not on my pc and have no idea how to cut and paste on a blackberry tablet.
Just had a look at those cables and they look like my RSW solutions cable. Could I not use that with Navcoder? |
My rsw cable didn't work, think that's specific to all comes
I'll have a look later, thanks.
That's the correct place for the antenna.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
My ULF was mounted on the outside of the amp bracket. I had to remove the Amp & bracket, then drill a couple of holes in the bracket, mount the Amp & ULF before installing the bracket back in the vehicle.
thatgirl101 Member Since: 28 Feb 2014 Location: London Posts: 45 ![]() ![]() ![]() |
Hi all,
If you just put pin 32 to 36 nothing will happen. It needs to connect whilst 36 is still connected to the ULF and earth.
Big_Al Member Since: 10 Sep 2014 Location: Essex Posts: 12 ![]() ![]() ![]() |
Hi anyone know if Baris is still selling a bluetooth adapter harness for L322 |
