![]() | Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery |
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 ![]() ![]() |
Hi Dixy - has your car actually ever not started or are you just getting the warning message? |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1101 ![]() ![]() |
No the car has never failed to start, just this irritatin bong, did it at the shoot last week not good PR. Changing dealer is not practical, I live in a rural area, 4 dealers with in an hours drive, 3 are part of same group, the 4th is the furthest away and I have had less than perfect experience of them.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Dixy, you need to put a solar charger in it. I put one in my supercharged after it wouldnt start at a shoot and it's been great. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Point is you shouldn't have to after dropping £70k+. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 ![]() ![]() |
Dixy
x-box Member Since: 18 May 2012 Location: uk Posts: 76 ![]() |
so, guys, how is the battery issue? it is been solved? by the recall? |
in that the new design is for the FBH to run for 17 minutes ?
About three minutes of the radio on low volume with the engine off and the damned thing shut down displaying a low battery warning on the info screen.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Was loading the car to go to the airport and it displayed! Oddly, on the return it was fine after sitting for 10 days! |
It's more annoying because an interior light was left on in our Discovery 3 for the best part of the week and it didn't make any difference whatsoever, yet two minutes of Radio 4 shuts the whole thing down in the Range Rover.
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I had a similar problem. The dealer changed the settings as the system shut down when the battery charge went down to about 75% as set at the factory. They reset it to 40% before the system shut down. I've had no problems since. Current MY2020 Gone: 1 x L405 and 2 x L322's |
Warranty up fairly soon, so possibly the last attempt to get this sorted - whatever the dealer has done previously (apart from say there's nothing wrong with it) hasn't worked, and there appears to be no real pattern to it occurring. Couple of miles, left for a week - no problem. Two hundred miles, left overnight - "Please start engine".
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
As I'm not daily or weekly on the forum, I've mist this item on which I would like to comment with my experiences. According my dealer they have changed the battery twice, last time they also changed the battery sensor located in the main cable connecting to the battery plus pole. This sensor gives you the low battery signal and cuts out the FBH. With the new sensor the FBH should go on longer....but have not been able to test it as this years winter was to hot. During the 2012 summer, the car sat still for 4 weeks and guess what: all juice gone and it take me more than 6 hours loading to get it started again. RR 2012MY TDV8 AB ipanema sand RR 2004 TD6 sold now |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
OK, I have read all the way through this thread. I often get the "Battery Low - Start Engine" message. It can happen if the internal lights have been on for more than a couple on minutes. When I first got the car 6 months ago, I assumed the battery was on the way out, (it had a LR AGM battery fitted, which I think had been a warranty replacement), so I replaced the battery with a new AGM, but the warning still appears with monotonous regularity.
