Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery
Page 12 of 13 <123 ... 111213>
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Dixy
Change dealer !
if that doesn't work, write to LR direct. My MY2011 is being looked at again this week to have another go at sorting out the problem with a member of the LR "Executive Office" getting involved.
A major mercy I have is that the design of the car to stop the battery going completely flat is working, but the trade off means I get an ineffectual FBH - which when you consider the cost of the unit is not acceptable.
Write a polite letter....they will respond.
Post #92196 14th Nov 2011 8:05pm
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
Dixy wrote:
Spoke to them again, getting seriously Censored off with it bleeping most mornings. Has anyone had any more joy?
Hi Dixy - has your car actually ever not started or are you just getting the warning message?
Post #92197 14th Nov 2011 8:06pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
No the car has never failed to start, just this irritatin bong, did it at the shoot last week not good PR. Changing dealer is not practical, I live in a rural area, 4 dealers with in an hours drive, 3 are part of same group, the 4th is the furthest away and I have had less than perfect experience of them.
Got home tonight to find recall letter from them. letters not necessarily in the right order
Post #92219 14th Nov 2011 9:49pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Dixy, you need to put a solar charger in it. I put one in my supercharged after it wouldnt start at a shoot and it's been great.
Post #92241 14th Nov 2011 10:49pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Point is you shouldn't have to after dropping £70k+.
Post #92246 14th Nov 2011 10:54pm
Rambles
Dixy
Sounds like the recall work is going to be done. It should cure the annoying bong. It did with mine....and now the car battery will only bong when it is within a inch of failing to start the engine rather than the country mile it was set to at manufacture.
Am not sure what good a solar trickle charger will do....some people like them, some don't. On a £75K car, it shouldn't need one IMHO.
Post #92300 15th Nov 2011 8:58am
x-box
so, guys, how is the battery issue? it is been solved? by the recall?
Post #122594 18th May 2012 8:59pm
Rambles
in that the new design is for the FBH to run for 17 minutes ?
yup - the recall has now fixed it so that you get slightly more than a half cycle going by the old tried and tested cycle times.
some people say that 17 minutes is more than adequate.
some say it is not.
I am in the latter camp.
but LR are not going to change it just for me.
I think the major change they made to the electrics was not the battery, but the installation of a level battery management system.
there are some fortunate people who never experienced any problems with the FBH - so are still on a 30 minute cycle. but one day.....these people will find themselves sitting in a warm cabin, whilst waiting for LR assist to turn up and give them a jump start.
Post #122633 19th May 2012 10:06am
Philip
About three minutes of the radio on low volume with the engine off and the damned thing shut down displaying a low battery warning on the info screen.
Car was supposedly confirmed as built post-recall with the latest software/gel battery etc. when the dealer was asked to investigate the previous low battery warnings - very annoying.
Post #126398 15th Jun 2012 9:12pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Was loading the car to go to the airport and it displayed! Oddly, on the return it was fine after sitting for 10 days!
Post #126417 16th Jun 2012 9:09am
Philip
It's more annoying because an interior light was left on in our Discovery 3 for the best part of the week and it didn't make any difference whatsoever, yet two minutes of Radio 4 shuts the whole thing down in the Range Rover.
It's had a CTEK charger on it all day and still isn't showing as charged ...
Post #126484 16th Jun 2012 7:07pm
AMD
I had a similar problem. The dealer changed the settings as the system shut down when the battery charge went down to about 75% as set at the factory. They reset it to 40% before the system shut down. I've had no problems since. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #126489 16th Jun 2012 8:07pm
Philip
Warranty up fairly soon, so possibly the last attempt to get this sorted - whatever the dealer has done previously (apart from say there's nothing wrong with it) hasn't worked, and there appears to be no real pattern to it occurring. Couple of miles, left for a week - no problem. Two hundred miles, left overnight - "Please start engine".
Friend has one a month or so older (albeit Belgian-spec), and his apparently hasn't done it once in 150k km.
Post #263193 4th Jun 2014 2:16pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
some say it is not.
As I'm not daily or weekly on the forum, I've mist this item on which I would like to comment with my experiences.
According my dealer they have changed the battery twice, last time they also changed the battery sensor located in the main cable connecting to the battery plus pole.
This sensor gives you the low battery signal and cuts out the FBH.
With the new sensor the FBH should go on longer....but have not been able to test it as this years winter was to hot.
During the 2012 summer, the car sat still for 4 weeks and guess what: all juice gone and it take me more than 6 hours loading to get it started again. RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #264273 9th Jun 2014 9:28pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Battery Low Start Engine
OK, I have read all the way through this thread. I often get the "Battery Low - Start Engine" message. It can happen if the internal lights have been on for more than a couple on minutes. When I first got the car 6 months ago, I assumed the battery was on the way out, (it had a LR AGM battery fitted, which I think had been a warranty replacement), so I replaced the battery with a new AGM, but the warning still appears with monotonous regularity.
This is a 2011 TDV8 Vogue, first registered 26 Mar 2011, VIN SALLMAMJ3BA348315, so not within the affected Vin range I think
The IID Tool shows voltage as 14.7 with engine running and 13.0v after engine shut down.
So should I just ignore these warnings, or is there a genuine fault here which needs to be investigated.
BTW there were a number of faults listed by the IID Tool; audio amp, HVAC ventilation, IPC Instrument Pack, PDM Passenger door. I don't know if maybe they have a bearing 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #361853 12th Dec 2015 4:14pm
