![]() | Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
Did you replace the air filter as well, or is that a pure EGR removal gain? I'm getting about the same, but not sure what part that was down to! __________________ 2015 FFRR SDV8 2011 FFRR TDV8 4.4 - Gone 2005 FFRR TDV6 - Gone |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
my air filter was replaced recently and although i got a slight mpg increase initially it soon settled down to normal..
i'm getting 24+ mpg around town ..thats an increase of 3/4 mpg..and the drive seems smoother.. |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Here are some pics of the old EGR valve that was removed from my TD6
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
The thing with the gunge in the EGR, is that it will have coked up everything "upstream" of it, including the inlet manifold and inlets within the cylinder head.. |
We didnt have time to clean out inlet manifold but we could see inside. It wasn't too bad tbh. The EGR was by far the worse effected by the gunge due to the narrower area. When I have more time I will prob get the inlet manifold sorted. FFRR TD6 HSE
there's going to be an influx of second hand egr valves on ebay soon.. |
ha, yes I was gunna clean my egr valve and chuck it on ebay to see what it'll fetch. Not a lot I'm thinking. FFRR TD6 HSE
I hope so too |
i've just looked on ebay and there doesnt seem to be any on there...... |
A workshop "paperweight" then.... |
but none on ebay must be a good thing cos if you list one it'll be brought straight away.....we hope. |
It'll be a race to sell EGR's on Ebay now! |
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 ![]() ![]() ![]() |
Same here, averaging around 24+ now, but that's with just blanking off the vacuum hose. Didn't get time to look inside the EGR but with only 20k on the clock hopefully it won't be too coked up. Driving is defiantly smoother, acceleration seems better also. Time will tell we'll see what happens over the next couple of months ![]() |
