Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 13 of 15 <123 ... 12 131415>
my mpg has definitely improved...swindon to brussels and back on one tankful of diesel..589 miles at 28mpg...last year before the egr blank i only got 24mpg..
Post #94743 27th Nov 2011 5:32pm
dave.s
mine is now booked in for service and egr blank on tuesday, so hopefully should be
a noticable improvement.
dave
Post #95561 1st Dec 2011 4:47pm
mjdronfield
Well, I fitted mine as I just don't agree with dirty exhaust gasses being fed back into the engine.
The intake tract gets clogged up with black sludge. Not so easy to clear out the inlet manifold on the Td6 unit though.
Any mpg improvement is a bonus.
I've only had the Rangie for a couple of weeks and its been removed already, but I did the egr mod to my previous Td5 a few years ago, and never looked back.
Get it taken off......
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #96255 5th Dec 2011 8:18am
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
.... but isn't the EGR system an anti pollution measure?
Post #96374 5th Dec 2011 8:12pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
the egr is only an anti pollution measure when the engines brand new and running on a test bed, in real time after the engine has covered a few thousand miles it becomes completely the reverse as it blocks the inlet with black sludgey crap that starves the engine of air reducing power and mpg and producing smoke. i think half the crap they fit to modern engines is a gimick to keep the tree hugers happy, if only they understood how an engine works they wouldnt be so quick to condem.
Post #96380 5th Dec 2011 8:42pm
If you can get better MPG from an engine its surely better for the old polar bear anyway as less is going out of the exhaust.
The other by product of the EGR is to aid in warming of the engine.
Bit useless as most TD6's came with an FBH if not all which is a very enviromental way of heating the engine and the cabin!
Post #96389 5th Dec 2011 9:03pm
speedymarktd6
Ive baught an allisport kit hopefully its here befour the weekend so i can fit it and i will report my findings good or bad onto no6 Range Rover
Everyone needs a hobby
Post #96485 6th Dec 2011 2:57pm
mjdronfield
OK, there just had to be a picture of a poor old polar bear. I feel guilty now.
That or I'm just fancying a mint..........
I thought the egr was only of any real use when the quality of the diesel is bad......ie, not in this country anyway....
....could be wrong.......
Smile 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #96487 6th Dec 2011 3:16pm
dave.s
picked up the range after service and egr kit fitted; will have to wait till weekend for a bit of a run.
when fitter took it for a test run it blew the air intake pipe off when booting it so had to refit over the flange
so dont know how this goes with the alisport one.
dave
Post #96495 6th Dec 2011 4:25pm
Still getting the same reported mpg now I have reconnected the EGR ..... .
Post #96509 6th Dec 2011 6:13pm
speedymarktd6
Fitted the allisoort egr blank kit very easy took about 30 minutes start to finish
It appears to have a little improvement in low down torque but other than that i cant really tell any difference
Oh well if its not there it cant break so im going to leave it on and see what happens onto no6 Range Rover
Post #97000 10th Dec 2011 3:54pm
give it time mark and you will find an improvement.. ... - .- -.
Post #97010 10th Dec 2011 4:29pm
CarMan
2006 Range Rover Vogue Td6 Zermatt Silver
Allisport EGR bought some weeks ago but as the instructions were for a 2litre BMW I was going to get my mate to help. Anyway, he's been busy I so I decided to do it myself this morning with a little help from FFRR.com and hey presto it's done and with no dramas, which is quite an achievement for me! Very Happy
What next . . . . . . . .
Post #97106 11th Dec 2011 2:10pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
"What next...."
Nothing just drive and enjoy
Gary
Post #97108 11th Dec 2011 3:26pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Well I just fitted blanking plate EGR removal to 2005 Td6 after 1st getting remap (emaps), then full service including crank cas filter and can report the following re mpg:
1. Before doing anything 22mpg over 1 month
2. Remap 23mpg over 2 weeks
3. Service 23.6mpg over 2 weeks
4. EGR removal 30.7mpg over just one trip to work and back which I do every day and usually get 24mpg after zeroing the trip meter.
Now obviously this isn't over a long period but seriously drove the same as I ever do over the same route with similar traffic to normal. I imagine with time the overall improvement wont be as good but its definitely an improvement.
Job was very easy with the only challenge undoing the two lower bolts holding the original housing (far easier to put back with the replacement piece) and no error messages. Most of the time was taken cleaning out all the crud from the inlet side of the valve and am pretty sure the valve has been non functional due to all the build up so if any improvement in mpg is to be seen I would suggest disconnecting the valve is a non starter and the whole valve should be replaced allowing clean cool air into the engine.
Cheers
T
Post #104138 28th Jan 2012 5:13pm
