Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 11 of 15 <123 ... 101112 131415>
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
Reformed wrote:
I am reading all these posts and keep thinking do I or dont I?
I like the sound of any improvement... Maybe if it goes through the MOT next week I might, although the bottom bolts looked fiddly to get at.
Just try blanking the vacuum hose to start with, it'll cost you next to nothing in time and money, if you see some results, maybe the EGR blanking kit may improve it further if it's not closing properly. Nothing to loose but some time. Thumbs Up and an M4 screw
Post #81333 14th Sep 2011 8:06pm
blanking the vacuum pipe is a good idea and if the egr valve is in the open position you should get some improvement...
looking at the inside of the egr valve there is some air flow restriction and fitting the bypass kit can only increase that air flow so benefiting the smoother running of the engine..
Post #81336 14th Sep 2011 8:15pm
Deep Down
The only reason I've not fitted the blanking kit is it's still under warranty, after that it'll be changed. Thumbs Up
Unless I've won the lottery before it expires..... Rolling with laughter
Post #81339 14th Sep 2011 8:23pm
i think we are all waiting for our numbers to come up.. Wink
Post #81340 14th Sep 2011 8:26pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I'm next!! I've got a 4.4 TDV8 Autobiography with my name on it. Just need to win the money. Big Cry FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #81341 14th Sep 2011 8:28pm
Here's a little photo how to on the EGR to encourage mechanical virgins
http://www.fullfatrr.com/gallery/thumbnails.php?album=339 .
Post #82020 17th Sep 2011 3:54pm
You mean closed, right? .
Post #82022 17th Sep 2011 4:05pm
the position so that air goes through it.. Mr. Green ... - .- -.
Post #82024 17th Sep 2011 4:14pm
will the author allow his work to be added to the wiki.. Very Happy Thumbs Up ... - .- -.
Post #82025 17th Sep 2011 4:16pm
With pleasure .
Post #82026 17th Sep 2011 4:22pm
Laughing @ Scarey
The blanking kit blocks the exhaust gases, removing the vacuum pipe means the EGR valve cannot open to allow the exhuast gases through, so the only air flowing is up from the intercooler. That's what you mean, init? Smile .
Post #82029 17th Sep 2011 4:24pm
absolutely joe.. Laughing
'how to' placed into the wiki... Thumbs Up ... - .- -.
Post #82030 17th Sep 2011 4:27pm
@Joe
Excellent write up with good graphic support.
Good to see somebody else thinks buying an "egr byepass kit" is an un-necessary expense. Leaves the car as built so that when you come to sell you can simply refit the vacuum hose and the car is then as original.
Post #82036 17th Sep 2011 5:16pm
I've just done a week of normal driving, distance of 220 miles, average speed 38 mph, average mpg 24.5 (computer), 22 mile runs of country, motorway and urban traffic. Will report back next week on mpg and performance following the same pattern of driving. Should give a good indication of any changes / improvements. Smile .
Post #82063 17th Sep 2011 7:25pm
Reformed
If mine goes through the MOT ok this week,this will be my weekend job. I think this is the route I will take. Reformed
Post #82085 17th Sep 2011 8:22pm
