Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 9 of 15 <123 ... 8910 ... 131415>
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Good work Stan
Mines been done as well. My old egr valve was grubby as well. I'll post some pics when I get a chance. Just done 20-30 miles and got up to 29mpg. However I'll wait a week or 2 before I decide whether it's made any difference. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #80093 9th Sep 2011 4:08pm
not driven mine yet, but it will take a while for things to settle down and get true mpg readings..i
Post #80110 9th Sep 2011 6:02pm
took mine for a run down the m4 and got this reading so i'm pretty chuffed at the result so far..
Post #80418 11th Sep 2011 3:08pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Thanks Stan
What mpg where you getting before
Gary
Post #80426 11th Sep 2011 3:56pm
at 70 mph it was about 27/28..
Post #80431 11th Sep 2011 4:08pm
nicedayforit wrote:
I don't understand the need to buy a kit.
Remove the valve, clean it out, check that it is closed to the exhaust inlet, refit it.
Don't reconnect the vacuum pipe but plug the end of it.
Job done, nil cost. But if you want to spend money on shiny bits....... Very Happy Rolling Eyes
I'm with nicedayforit on this. If you only need to prevent exhaust gases getting into the engine and not the airflow from the intercooler pipe, then ensuring that the EGR valve remains closed by removing the vacuum pipe should produce the same effect?
Oh, scarey, nice MPG figure, used to be able to get that in my P38A (V8 petrol) at steady 70, but never anywhere like it with my TD6.
I too am working on sorting out gearbox problems before i move onto this one Wink .
Post #80440 11th Sep 2011 4:46pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i am watching this with great interest. since i had the FFRR chipped i can break 30 mpg on the trip computer easily and was wondering if there is more to be gained down the EGR route.
the only problem is that the trip computer seems to be really on the high side.
i have just dragged my caravan over 600 miles in the last couple of weeks and kept a log of fuel and mpg etc.
when i did a full to full workout on paper when the trip was reading an average of 26mpg in reality it was only 20mpg on paper.
sorry to be the bearer of bad news!! can someone do a full to full check to get some real figures?? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #80450 11th Sep 2011 5:57pm
33CHINACARS
Regardless of what the real mpg is by fitting the EGR kit its an improvement and well worth the effort. IMHO
Will also be fitting a Blue fin chip ???
Gary
Post #80501 12th Sep 2011 2:18am
stu
i agree 100% any gain is well worth it. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #80503 12th Sep 2011 4:30am
@stu, my mpg readout is very accurate as i found on a tank to tank calculation i done on a 75/80 mph journey over a hundred miles...result on readout was 24 mpg and 'real' mpg was 23.8 ...
Post #80505 12th Sep 2011 6:48am
stu
mine is rubbish then!!! i did over 300 miles in one go last week tank to tank and the trip computer was 6mpg out.. Sad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #80732 12th Sep 2011 8:07pm
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
EGR Isolated
Took the vacuum hose off and blanked it with an M4 x 20 screw.
Seems to have worked, now registering that I'm getting an extra 2mpg, I can get it up to 32mpg on the motor ways at 70mph, averaging about 24 to 25mpg with mixed driving long/short runs, lots of winding roads etc on MTRs.
What is everyone else averaging?
Post #80828 13th Sep 2011 9:21am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I reset my trip about 1500 miles ago and I have averaged 25.5mpg since, which I believe is quite accurate as I compared the displayed mpg a while ago with actual tank top-ups and it was less than 1 mpg out. On a 300 mile round trip to Cardiff a few months ago (no motorways but decent A roads and duel carriageway etc) I averaged 30 mpg No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #80843 13th Sep 2011 10:39am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Your MPG readings from the computer may not be accurate, but they will be relative.
If previously you were getting 22MPG and your now getting 24 MPG, thats still a ~10% improvement, regardless if your actual MPG was 18 or 25.
In regards to just blocking the vacume tube, that may work, but only if your lucky enough in that your valve wasn't jammed open with gunk (see Scarey's and my photos of egr valves) before you blocked off the control __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #80857 13th Sep 2011 11:33am
removing the egr valve and blanking it off is defo the way to go ..i'm getting between 3/4 mpg more at the moment ..it'll need a month or so to get a proper mpg average but its looking good..
Post #80858 13th Sep 2011 11:33am
