Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
Happy new year all!
3rd Jan 2025 9:56pm |
So with help from fantastic forum member Pawl I have been able to conduct a pressure test on the power steering system.
12th Jan 2025 10:23pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 759 |
i am sure i have posted before that i have had power steering problems, and lately its got worse.
13th Jan 2025 12:51am |
Yours sounds like an issue with the servotronic valve or BCM Knares.
13th Jan 2025 7:18pm |
i seem to have lost my power steering altogether now RR 2005 4.4 petrol
14th Jan 2025 12:48pm |
Have you looked at diagnostics to see if your BCM is outputting the correct pwm signal to the servotronic valve Knares?
17th Jan 2025 9:29am |
interesting
18th Jan 2025 3:06am |
Its fitted inline between the power steering pump and the high pressure hose to the rack.
19th Jan 2025 9:10am |
manufactured 12/12/04
20th Jan 2025 12:07am |
20th Jan 2025 12:10am |
It should be under BCM (body control module)
20th Jan 2025 11:05pm |
some time ago, i came across a guy wrecking his RR, same year as mine, i bought a heap of control units off him, all i could find.
21st Jan 2025 8:07am |
Have you only just fitted the replacement BCM?
21st Jan 2025 10:36pm |
So today I've spent hours out in the 'storm' removing the lower steering shaft to inspect the UJs.
24th Jan 2025 9:35pm |
