![]() | Home > My Range Rover > 5 RRs and I have to give up |
3 old shocks and 1 new one would certainly make for a non optimal ride quality but at least the non CVD shocks are cheap and that should be an easy fix. Tyres and tyre pressure make a big difference on steering forces at low speed and IME OE pressures are a bit on the low side - what tyres and what pressures are you running?. I can palm mine if needed but it's not the lightest steering on a car I've had but then I don't like overly light steering anyway. 2012 TDV8 Vogue (L322) |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 782 ![]() ![]() ![]() |
my steering, when it decides to work, which is 95% of the time, is as light and positive as can be RR 2005 4.4 petrol
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 726 ![]() ![]() |
Agreed on the shocks,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
You don't think that the oversize tyres contribute to extra steering load? |
I'm aware they will have an effect Graeme but it was no different on the 255/50/20 it had when I got it. |
Just looking for possible reasons... |
Taller sidewall shouldn't impact the tread patch - wider tyres maybe. Try upping the pressures and see if it's any better. After a lot of experimentation I now run 37 allround. 2012 TDV8 Vogue (L322) |
I've tried this one at 36 psi all round and all the others I've owned.
The servotronic valve/modulator could be partly blocked but they're rather expensive to replace then discover that yours was OK. |
I do need to have a look at the servotronic on this one Graeme, it could be sticky/stuck as you suggest.
There's a very fine gauze filter on the inlet to the valve which could be partly blocked. You could try removing it and at the same time temporarily remove the small o-ring from the valve so that some oil is able to bypass the valve thereby increasing the overall flow. |
I didnt know about the filter Graeme, does that sit inside the orifice the valve fits in to?
Yes, the little filter is located in the rack neck ahead of the modulator.
Great thank you Graeme, that's given me something new to check.
