Home > My Range Rover > 5 RRs and I have to give up
Page 1 of 15 123 ... 131415>
MarianaWestminster
Yes another moan...
I've been trying desperately over the past 5-6 years to recapture the love I had for my first L322 3.6.
After selling the dreadful L405 back in February and saying 'no more' I bought a large diesel saloon for daily driving purposes and I've been largely happy with that.
But the desire to recapture the love and have a working and enjoyable RR in my fleet was just too strong so when a 2006 TDV8 came up for sale cheap with issues I dove in head first. (This was in April)
I've done plenty of work fixing it up and getting an MOT.
Now driving it round I'm dissapointed yet again as it's exactly like the last 3 RRs.
Lethargic and laggy engine, heavy steering and the ride quality isn't right although this time it's not too hard/firm but too bouncy. (This 2006 doesn't have adaptive damping like the 09, 11 and 2015 I've had)
I'm not asking for help or anything as I know it's unfixable just venting.
Post #700984 28th Sep 2024 9:11am
Vogue
Really ? It’s 18 years old - what did you expect 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #700986 28th Sep 2024 9:45am
I know a good therapist.... Having driven your 405, which seemed perfect to me, I have to say I think a lot of your disappointment maybe because you don't really want one...
Stick with the saloon and enjoy that.... Thumbs Up Pete
Post #701001 28th Sep 2024 12:18pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Step into a 5.0 and the smile will return
Post #701007 28th Sep 2024 1:26pm
mjdronfield
Mines gonna cost me about £2600 next week, it can’t be worth any more than 10k. I’ve only done 1500 miles this year. Questioning my sanity too…. 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #701020 28th Sep 2024 5:59pm
Mr Tee
Yup get a 5 litre , expecting a revelatory experience in an old full fat might be too tall an order Thumbs Up
Post #701024 28th Sep 2024 6:24pm
JayGee
Re: 5 RRs and I have to give up
MarianaWestminster wrote:
Yes another moan...
New shocks on each corner will fix the bouncy ride and an EGR delete may fix the laggy engine response. 2012 TDV8 Vogue (L322)
Post #701065 29th Sep 2024 11:18am
He tried new shocks all round along with lots of other bits and reckoned it was just the same, and that was across three fatties IIRC.... Rolling Eyes Pete
Post #701067 29th Sep 2024 12:48pm
JayGee
New shocks definatley improved mine after 170k miles on the old ones. Maybe slightly harder ride ( vastly improved with new tyres) but way better body control during changes of direction. I guess it depends how worn the original shocks were. Mine were still fully functional just not optimal. 2012 TDV8 Vogue (L322)
Post #701068 29th Sep 2024 12:54pm
GraemeS
Australia
I wear-out shocks in 80K Kms where I drive, although I put up with the worn CVDs by recalibrating until around 130K Kms because of their high replacement cost.
Post #701070 29th Sep 2024 1:10pm
JayGee
Never found the calibration feature in the GAP IID tool to do anything noticable. 2012 TDV8 Vogue (L322)
Post #701071 29th Sep 2024 1:12pm
MarianaWestminster
I openly admit that everything points to me being the problem and not the cars.
Anyone know a good therapist? Laughing
The ride on this one is likely to be shocks, 3 are original and 1 a replacement. There's no electronic control (CVD) as it's a 2006 so just plain old shocks with air bags.
I'm sure I'm not wrong when I say the steering should be 'palmable' which it was on the 2009 Westminster I had first.
The laggyiness of the engine could be down to me being hyper sensitive who knows.
My Westminster was quite simply the best car I'd ever owned right up until it blew it's boost hoses then was never right afterwards.
I think I'm in for a lifetime of buying and selling RRs until I finally find ones that drives 'right'. Very Happy
Post #701172 30th Sep 2024 8:08pm
GraemeS
Australia
For the heavy steering, you could try unplugging the electrical connector on the servotronic valve on the neck of the rack to check that the steering is then heavier at slow speed, as evidence that the valve is working. You could also check that the gauze in the bottom of the reservoir isn't mostly blocked, or simply whilst idling that there is significant disturbance in the reservoir indicating good surplus capacity from the pump.
Post #701183 30th Sep 2024 9:43pm
MarianaWestminster
Hi Graeme,
One of the problems this cheap example had upon collection was a noisy power steering pump.
I've replaced it with new, flushed and replaced the fluid, replaced the reservoir, found a leaky cooler and replaced it.
It's now quiet and there is good turbulence in the reservoir from the new pump but in my opinion it's still heavy.
It's not possible to 'palm' the steering as I used to do in my original Westminster.
Unplugging the servotronic valve makes it almost impossible to steer.
It's the same complaint I had about L322s #2, #3 and the L405.
None of them have been as light and easy to turn as L322 #1.
Post #701186 30th Sep 2024 10:30pm
JackRegan
When we look back, it's often in fondness.
My 2005 L322 drove differently when I changed from 18" to 20" wheels. Whilst steering was still vague and handling required good anticipation, it seemed less bouncy/wafty. When I switched to a 2011MY, everything was a little better, probably down to the newer suspension components. But I found the ride slightly firmer again.
I noticed a big change when I got the L405. Its drive was much more car-like, and its steering and handling were more precise in comparison to the L322. What is do remember is when the tyres got low (first set) or old (second set after 5yrs) the ride was harder and a bit thrashy, if that's the right word. This was on 22" wheels.
My memories of my first L322 on 18" wheels were its fantastic road presence, comfortable wafty ride, wonderful seats and a big steering wheel, I think most remember these characteristics. However, I bet I'd get a shock if I were to drive even a mint TD6 today. 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #701197 1st Oct 2024 7:20am
