![]() | Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 730 ![]() ![]() |
Thanks Knares,
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 786 ![]() ![]() ![]() |
BCM checked for operation and replaced with a good used part anyway.
No, no programming required in my case Knares, I bought one from an identical spec car.
i replaced the BCU with one i bought off a car the same year, it was an earlier model, every thing seemed to work, and other things that haven't worked since i bought the car.
Excellent work Knares!
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Just a thought, and I'm not sure if you've already mentioned this, but have you driven a car that is known to feel ok by it's owner as a comparison (not just what you remember from previous cars)? also, might be worth someone whose car feels ok to them having a drive of yours to see what they think. Back to back comparison. Drives:
I have when trying to diagnose the previous cars RVbush but not with this one.
So the temperatures have dropped again in my area (-2 this morning) and the steering has gotten a bit lighter/easier again.
Also I don't think it's because the road is icy due to cold and reducing friction.
Ok got it up in the air again and tried turning the hubs left and right at full droop and jacked up under lower control arm to ride height. (Anti roll bar link and track rod ends disconnected!)
i did replace a airbag recently, but i didn't take notice of anything.
I have a theory I'm mulling over at the minute.
New lower control arms with integral ball joints fitted today.
i wonder if the steering rack is partly seized RR 2005 4.4 petrol
