Home > My Range Rover > 5 RRs and I have to give up |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
A good 'result' - but bizarre 🤣 Paul,
20th Nov 2024 10:17pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 675 |
Steering back to being 'ok' today (not perfect but not terrible just manageable)
25th Nov 2024 8:15pm |
Okay so this RR is doing something different to all the others.
26th Nov 2024 9:30pm |
That is weird!
26th Nov 2024 11:33pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
Tyre presures are lower when cold than when hot. |
27th Nov 2024 12:16am |
I agree Pawl, I also agree Graeme.
27th Nov 2024 7:33am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
Cold makes the tyre compound stiffer which may cancel out or even over compensate for any pressure loss. Also I have found higher than stock pressures give me a better ride quality which maybe has to do with how tyre compliance interacts with velocity signals sent to the CVD ECU? Your drivability issues also sound like a leaky EGR valve and in cold weather the EGR valve opens less as I found recently when my average regen interval went from 80 to 560 miles and the EGR valve never opened more than 10-20 %.Worth checking the EGR error value and the difference between comanded and actual opening values . Mine seems to have a 4-5% error i.e the actual position is higher than the commanded. I'm now seriously toying with an EGR software delete. 2012 TDV8 Vogue (L322) |
27th Nov 2024 9:01am |
Interesting information Jaygee, I'm sure the tyre and it's pressure do effect the way the CVD module will control your suspension.
27th Nov 2024 10:36am |
I was assuming it was a late L322. No idea why the suspension should be stiffening up on a non CVD car or why you are getting drivability issues with blanked EGR valves other than the usual air leaks which cause similar issues. If you have a GAP IID tool it's worth checking the air intake temps and charge intake temps to see if they are 'plausible' Both MAF's I assume have IAT 's on them and should read the same and lower than the charge intake IAT. 2012 TDV8 Vogue (L322) |
27th Nov 2024 12:39pm |
Probably because I've made all these complaints about 2 later L322s before Jaygee
27th Nov 2024 12:47pm |
Maybe worth doing the EGR software delete anyway through the GAP tool add-on as it's a wise move anyway to protect the turbo's 2012 TDV8 Vogue (L322) |
27th Nov 2024 1:26pm |
It's something I plan to do Jaygee but sadly I haven't an IID tool at the moment.
27th Nov 2024 1:36pm |
A thought that crossed my mind, when I did the power steering fluid replacement I used Smith and Allan cold climate fluid.
28th Nov 2024 2:15pm |
Okay so this just gets more and more confusing.
29th Nov 2024 9:55pm |
