![]() | Home > My Range Rover > 5 RRs and I have to give up |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
The outside temperature sensors are not exactly scientific instruments and are rarely completely accurate . Ok when moving in clear airflow . Not accurate in slow traffic or stop start driving due to heat soak from a hot engine or even hot brakes . Might need a clean if it’s under reading . |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 693 ![]() ![]() |
Had a quick look at the external temp sensor behind the grill but there's nothing much to see, I think its working fine as it shows a fairly accurate temperature on the dash and in diagnostics.
The new BCM finally arrived yesterday, I've quickly fitted it this morning on my way out.
Just drained off some power steering fluid into a clear tub out of interest...
Well without much more direction I've ordered a replacement high pressure hose (pump to rack)
Fitted the new genuine high pressure hose from pump to rack and also double triple checked the security, routing and integrity of the feed hose from res to pump.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 195 ![]() ![]() |
I feel your pain. I wish I could add something and I hope you fix it soon. At least it starts and runs! 2012 Vogue TDV8 in Aintree green over sand |
Some things are a real headscratcher Toby, it should work but doesn't (or in my case it works but not as it should)
Just recalled I had the steering wheel off not long after buying the car. I didn't torque the retaining bolt to spec when putting it back on.
I could not find one in the 2006 WM but there is a troubleshooting guide in the facelift WM, though I suspect you would have already seen it. I can't imagine that they're much different in principle.
Thanks Toby,
Finally a break in the bad weather arrived so I set to checking the suspension for binding.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
If you can move things by hand then it wouldn't be stiff enough to cause the steering to feel heavy I wouldn't have thought. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
