Home > Technical (L405) > front knuckle cracking
Page 48 of 50 <123 ... 47 484950>
I’m in the VIN range and have had them checked, all Ok, and on that basis would probably be covered if they did go.
I’m working on the assumption that LR won’t change them as a matter of course if there is no cracking so for safety sake I have looked into prices. They seem to be about £650+vat a side for the bit….. a couple of hours on that for fitting. There is nothing that can't be fixed with a hammer😜😜
Post #708393 5th Jan 2025 7:21pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I would get LR to change them both.
I took mine in (as it's in the VIN range) and one was visibly cracked. They changed both anyway.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #708394 5th Jan 2025 7:35pm
cass
"I’m working on the assumption that LR won’t change them as a matter of course if there is no cracking"
I don't think this is the case, I was told by a normally very reliable JLR gossip that the problem was with clearly identified batches of parts. from this some VIN numbers WOULD have the suspect parts fitted, some VIN numbers would NOT have the parts fitted and some MIGHT have the parts fitted. He reckoned that the "inspection" involved confirming which parts were fitted to any given car, the suspect parts would be changed and the others would be checked and changed if required.
This seemed to be the case as he told me just from the VIN that my 2014 car would get both sides changed and this was the case even though there were no signs of cracking.
Post #708644 8th Jan 2025 3:19pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Totally correct, there is a production batch code etched into the knuckle, if it falls within the known bad batch they get replaced.
It's detailed in the N759 v2 recall document. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #708657 8th Jan 2025 6:44pm
Mikey
N759 is now on v3 Laughing
Today, a 16MY in for some repairs, a service + MOT
Batch numbers are higher than those listed in the bulletin...
From my reading of the bulletin, both of these should be replaced FOC under warranty. Let's see what happens
Post #709498 17th Jan 2025 8:38pm
4RRS
I can see this running and running!! I had both replaced as 'goodwill' on my MY2016 as outside of vin and batch. I also had a free o/s/f driveshaft as the MD managed to destroy it on removal (and their special tool). All in, a win for once!
Keep us posted. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #709500 17th Jan 2025 8:43pm
Mikey
Results are in, and the dealership says....
NO!
There are no recalls or service actions against the VIN number, so there is nothing for the dealership to claim against...
Post #709728 20th Jan 2025 2:52pm
4RRS
That's disappointing, it begs the question as to how they authorised mine as it was the same scenario. I didn't need to even argue, JLR CRC just came back to me and said we've instructed the dealer to complete the works as goodwill??
Very odd and expensive for the owner. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #709729 20th Jan 2025 2:56pm
JamboM3
Seeing as we are seeing more and more of these on newer L405's than the recall - it begs the question that if you have them replaced is it simply a matter of time before the problem happens again?
Post #709866 22nd Jan 2025 12:30am
From watching Christian and Vera on LR Time, who have just had theirs replaced, he noted the design/casting is different, so probably not. Got - 2017 SDV8 Autobiography in Loire Blue
Post #709927 22nd Jan 2025 9:58pm
Gremlin500
Equally, it could be the composition of the material which is different, or a change to the manufacturing process, or a combination of factors, but we will likely never know. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #709929 22nd Jan 2025 10:34pm
JamboM3
Hadn’t seen their latest, I’ll check it out. Reassuring at least, was beginning to think I may have to part ways with mine if this is going to be an ongoing concern. Ridiculous JLr haven’t widened the recall
Post #709933 22nd Jan 2025 11:15pm
Rio
France
[quote="alanm_3"]From watching Christian and Vera on LR Time, who have just had theirs replaced, he noted the design/casting is different, so probably not.[
When I observed the design/casting differences,
I wrote to Christian to show him the differences, and that they could confirm. You have my photos in the post.
But I haven't found the new casting yet even on MY18/19...
People who have the latest l405 MY22 should look at their knuckles.
Post #710566 29th Jan 2025 9:15pm
Glackowitz
United States
I bought a replacement knuckle out of my own pocket and had it installed. The dealer im working with says they still dont have parts to fix units in the recall. From what I was told they will have a new design/casting to them. Dealer told me to keep old part as it will need to go back for inspection and my recently installed knuckle will be replaced with newer style.
JLR NA says they were sending letters out on Jan 3 2025, I havent received one as of yet and Im in the Production and VIN range.
Post #710580 30th Jan 2025 1:05am
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Another 2017 failure
https://www.facebook.com/share/p/162H1LzUQS/? 2017 (67) Vogue SE Corinthian Grey
Post #710870 2nd Feb 2025 8:26pm
