Home > Technical (L405) > front knuckle cracking
Page 48 of 48 <123 ... 464748
I’m in the VIN range and have had them checked, all Ok, and on that basis would probably be covered if they did go.
I’m working on the assumption that LR won’t change them as a matter of course if there is no cracking so for safety sake I have looked into prices. They seem to be about £650+vat a side for the bit….. a couple of hours on that for fitting. There is nothing that can't be fixed with a hammer😜😜
Post #708393 5th Jan 2025 6:21pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I would get LR to change them both.
I took mine in (as it's in the VIN range) and one was visibly cracked. They changed both anyway.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #708394 5th Jan 2025 6:35pm
cass
"I’m working on the assumption that LR won’t change them as a matter of course if there is no cracking"
I don't think this is the case, I was told by a normally very reliable JLR gossip that the problem was with clearly identified batches of parts. from this some VIN numbers WOULD have the suspect parts fitted, some VIN numbers would NOT have the parts fitted and some MIGHT have the parts fitted. He reckoned that the "inspection" involved confirming which parts were fitted to any given car, the suspect parts would be changed and the others would be checked and changed if required.
This seemed to be the case as he told me just from the VIN that my 2014 car would get both sides changed and this was the case even though there were no signs of cracking.
Post #708644 8th Jan 2025 2:19pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Totally correct, there is a production batch code etched into the knuckle, if it falls within the known bad batch they get replaced.
It's detailed in the N759 v2 recall document. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #708657 8th Jan 2025 5:44pm
