![]() | Home > Technical (L405) > front knuckle cracking |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 150 ![]() ![]() ![]() |
I would get LR to change them both.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
"I’m working on the assumption that LR won’t change them as a matter of course if there is no cracking"
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Totally correct, there is a production batch code etched into the knuckle, if it falls within the known bad batch they get replaced.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
N759 is now on v3 |
I can see this running and running!! I had both replaced as 'goodwill' on my MY2016 as outside of vin and batch. I also had a free o/s/f driveshaft as the MD managed to destroy it on removal (and their special tool). All in, a win for once!
Results are in, and the dealership says....
That's disappointing, it begs the question as to how they authorised mine as it was the same scenario. I didn't need to even argue, JLR CRC just came back to me and said we've instructed the dealer to complete the works as goodwill??
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 273 ![]() ![]() ![]() |
Seeing as we are seeing more and more of these on newer L405's than the recall - it begs the question that if you have them replaced is it simply a matter of time before the problem happens again? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
From watching Christian and Vera on LR Time, who have just had theirs replaced, he noted the design/casting is different, so probably not. Got - 2017 SDV8 Autobiography in Loire Blue
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1879 ![]() ![]() ![]() |
Equally, it could be the composition of the material which is different, or a change to the manufacturing process, or a combination of factors, but we will likely never know. V6 Vogue - “Less is More” - less to go wrong! |
Hadn’t seen their latest, I’ll check it out. Reassuring at least, was beginning to think I may have to part ways with mine if this is going to be an ongoing concern. Ridiculous JLr haven’t widened the recall |
Rio Member Since: 03 Jun 2024 Location: Albi Posts: 24 ![]() ![]() |
[quote="alanm_3"]From watching Christian and Vera on LR Time, who have just had theirs replaced, he noted the design/casting is different, so probably not.[
Glackowitz Member Since: 06 Sep 2020 Location: Oregon Posts: 18 ![]() ![]() |
I bought a replacement knuckle out of my own pocket and had it installed. The dealer im working with says they still dont have parts to fix units in the recall. From what I was told they will have a new design/casting to them. Dealer told me to keep old part as it will need to go back for inspection and my recently installed knuckle will be replaced with newer style.
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 120 ![]() ![]() ![]() |
Another 2017 failure
