Home > My Range Rover > 2012 Vogue TDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8345 |
I don't recognise the location as not had your model, but that build up of gunk in the big pipe to the right doesn't look good...!!? Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
3rd Dec 2024 10:46am |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 184 |
Standard stuff for an EGR-equipped TDV8. 2012 Vogue TDV8 in Aintree green over sand |
3rd Dec 2024 11:17am |
Right, I was being a numpty and not for the first time. I did not press down on the brake pedal enough which the manual does mention 'in certain conditions' should be firmer. Ignition on for 60 seconds to prime and then crank.
4th Dec 2024 9:15am |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 153 |
Wow, I have just read through all 9 pages, you have the patience of a saint and hats off to you for being brave enough to tackle so many jobs. The best of luck getting this back on the road and useable daily. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
4th Dec 2024 11:03pm |
Another play today. I have not been able to make SDD work with the Mongoose cable, as expected. However, I did update the firmware in my cheapy code reader and that connected OK. Why did I not do that earlier?
15th Dec 2024 2:23pm |
Reconnected the battery and no codes in the reader but now it says DPF full on the dash.
15th Dec 2024 3:55pm |
I think the next step in this palaver is to carry out the TSB regarding the fuel pressure sensor harness mod. Mine does not have it. Without any meaningful codes to go on I am clutching at straws somewhat but it does not look too bad a job, even for me.
15th Dec 2024 5:41pm |
The modified harness, 3 connectors and the 4 studs that rounded holding the TB bracket ordered from Marshall for delivery tomorrow. All cheaper than the eBay sellers even at retail. 2012 Vogue TDV8 in Aintree green over sand |
16th Dec 2024 10:56am |
I managed to achieve a little at lunchtime. I know this isn't going to be the issue but for the sake of £40-ish it's worth spending to rule it out.
17th Dec 2024 3:11pm |
As expected, the modified harness has made no difference but I don't appear to have introduced a new problem. There are no codes stored on my Autel reader.
19th Dec 2024 3:09pm |
After successfully buying a stolen and locked GAP tool from eBay (promptly refunded and thanks to the good service from Patrick at GAP - do not buy serial number 20D-9857), I have managed to buy one from jimdonut of this parish. Many thanks Jim for the speedy delivery and communication. Top man.
14th Jan 2025 11:19am |
The weather has been acceptable today so I have tidied the aforementioned harness and it is now in the supplied conduit.
25th Jan 2025 2:57pm |
