![]() | Home > My Range Rover > 2012 Vogue TDV8 |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Have you got one of these ?
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 52 ![]() ![]() ![]() |
Not cheap at £30 the set on Amazon, but you’ll use them time and time again. I haven’t found an exhaust manifold bolt, injector bolt (same type as you need to remove) or even swollen LR alloy wheel nut that these type of extractors won’t remove.
Never seen them before they look good 👍 |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 231 ![]() ![]() |
After much procrastination and August just about over, these turned up today. I shall reinvigorate my efforts tomorrow/the weekend.
Yep, 6mm is too wide. Damn and blast, another weekend gone. I'll see if any local firms have anything that will work before eBay again.
Nearly there! The good-old 2-nut method has removed the two on the right. One of the left was gripped by the new socket - lovely. That leaves one more where access is hampered by a connector. Patience and temper were fraying so I have called it a day and I'll have a beer whilst watching F1 qually.
More slow progress but at least it is progress.
The doughnut is off but I still need to remove the brace for access so this may end up being drilled.
I have noticed some dried coolant on the left side of the oil cooler. There are also some hoses in poor condition so replacements are in order whilst I am here.
The oil feed pipe bolt did not round but it felt close. I will have to order a new one.
Horrible, horrible, horrible! Brake cleaner doesn't cut it so Mr Muscle oven cleaner was used. It's not gleaming but the holes are open. If I keep it then I really think the EGR has to be deactivated.
Cleaning the Doughnut is a nasty, messy job but plenty of info on here about how it's been done by various people. I plugged the 4 outlets and filled it with kerosene to soak overnight and then used various brushes an scraping tools to remove what was left. Some of the deposits can be very solid and need more than a stiff brush to dislodge them. 2012 TDV8 Vogue (L322) |
Yep, I have no doubt you are correct. I need to buy a large storage box I think to use as a temporary 'tank'.
Some more small steps today. It appears that it is not possible to remove the 'stat housing from above which I had a sneaking suspicion would be the case. I cannot pull off the three hoses towards the front as the metal pipe below will not budge.
