![]() | Home > My Range Rover > 2012 Vogue TDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8532 ![]() ![]() ![]() |
I don't recognise the location as not had your model, but that build up of gunk in the big pipe to the right doesn't look good...!!? Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 234 ![]() ![]() |
Standard stuff for an EGR-equipped TDV8. 2012 Vogue TDV8 in Aintree green over sand |
Right, I was being a numpty and not for the first time. I did not press down on the brake pedal enough which the manual does mention 'in certain conditions' should be firmer. Ignition on for 60 seconds to prime and then crank.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 168 ![]() ![]() ![]() |
Wow, I have just read through all 9 pages, you have the patience of a saint and hats off to you for being brave enough to tackle so many jobs. The best of luck getting this back on the road and useable daily. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Another play today. I have not been able to make SDD work with the Mongoose cable, as expected. However, I did update the firmware in my cheapy code reader and that connected OK. Why did I not do that earlier?
Reconnected the battery and no codes in the reader but now it says DPF full on the dash.
I think the next step in this palaver is to carry out the TSB regarding the fuel pressure sensor harness mod. Mine does not have it. Without any meaningful codes to go on I am clutching at straws somewhat but it does not look too bad a job, even for me.
The modified harness, 3 connectors and the 4 studs that rounded holding the TB bracket ordered from Marshall for delivery tomorrow. All cheaper than the eBay sellers even at retail. 2012 Vogue TDV8 in Aintree green over sand |
I managed to achieve a little at lunchtime. I know this isn't going to be the issue but for the sake of £40-ish it's worth spending to rule it out.
As expected, the modified harness has made no difference but I don't appear to have introduced a new problem. There are no codes stored on my Autel reader.
After successfully buying a stolen and locked GAP tool from eBay (promptly refunded and thanks to the good service from Patrick at GAP - do not buy serial number 20D-9857), I have managed to buy one from jimdonut of this parish. Many thanks Jim for the speedy delivery and communication. Top man.
The weather has been acceptable today so I have tidied the aforementioned harness and it is now in the supplied conduit.
It seems my battery has had enough and will no longer hold charge. My CTEK charger threw the error at position 5. It is flat as a pancake. Great.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 904 ![]() ![]() ![]() |
these beasts need a positive message back from the ABS control module for the car to crank from the "Start Button" inside the car
