![]() | Home > My Range Rover > 2012 Vogue TDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
the passenger side of my engine cover post is also broken, it would be nice to replace it with a new one, as I doubt it will glue back - I wonder if they can be 3D printed, or if possible to buy them ?
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Looks like Maltings have them in stock, £5.03
thx Andy - I bet they sell a lot of those, and it will be nice to replace the broken one |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 241 ![]() ![]() |
Thanks Andy.
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 229 ![]() ![]() ![]() |
From your picture it looks like the 4 intake hoses have already been fitted with the upgraded ones, the front right doesn’t look to be on properly. |
Your powers of observation serve you well |
After a short break away I return to carry on with my new sockets, but it is to no avail. These torx screws/bolts will not budge and if I put too much torque they will round off, as I noticed some gorilla has already done to one on other side.
Do you have an impact driver as it will break the thread bond without applying too much torque - shock vs brute force 2012 TDV8 Vogue (L322) |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
I had the same issue and decided not to risk it, and I left that bracket in place. There are nuts under the bracket that you can reach to release the doughnut. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Get 2 nuts, run them down the thread, lock them together, then use the bottom one to remove the stud. G reg 2.5VM Vogue Portofino red 1991- 1999
I tried that but the stud was close to snapping so didn’t risk it.
OK thanks chaps. Some things to consider. 2012 Vogue TDV8 in Aintree green over sand |
If they are threaded into the head it will be galvanic corrosion not threadlock. 2012 TDV8 Vogue (L322) |
I liked this idea, I managed to remove one on the right but then two of the four throttle body bolts rounded off so I can't remove it for access. I expected a fight but not chocolate metal. I have lost my mole grips so I am considering the next plan of attack. I could Dremel notches and use a big screwdriver. It's too warm now in any case so time to chill and gather my thoughts. 2012 Vogue TDV8 in Aintree green over sand |
