Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 351 |
Are you sure the leak is not the pipe at the rear of the oil cooler? That’s a common place to leak. |
8th May 2024 8:25pm |
LRworkhorse Member Since: 24 May 2024 Location: Hamble Posts: 5 |
Did you find a fix to this mine is leak oil in the same area front of top engine bay |
24th May 2024 6:56pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 63 |
After 2000 km trip, I have a lot of oil on the engine cover where the throttle body is. Before the trip I put 3 o-rings on the air inlet connection to the throttle body, as described on this forum.
29th May 2024 1:46pm |
fredd589 Member Since: 24 Apr 2024 Location: Cambridge Posts: 19 |
Hi all, I checked mine this morning after noticing oil on the bottom of the undertray - no smell or dripping but is obvious if you look around the engine.
20th Jun 2024 7:38am |
Hi all,
10th Jul 2024 12:47pm |
How have people managed to tighten the 14mm bung on top of the oil cooler?
14th Aug 2024 6:12pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 828 |
is it this one shown below - go to nino nino post 28th May 2019 for more info
14th Aug 2024 6:44pm |
Just a quick update to say I managed to get access to this and (hopefully) seal it all up! I took the throttle body off in the end, which was the easiest way of getting a long 3/8 extension down as with the TB off it's almost straight down. With a 14mm hex socket - it was a tight fit but I managed to feel the socket onto the plug by feeling just behind the idler pulleys, and then sealing it up. Went out for a bit of a drive today and it was still dry when I got back so fingers crossed! |
18th Aug 2024 1:29pm |
PC76 Member Since: 28 Oct 2019 Location: Home Posts: 10 |
Hi all, I had a coolant leak on my 4.4TDV8 which I located to the drivers side of the oil cooler….
18th Oct 2024 7:49pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 123 |
Thanks to Craig for the guide and others who have contributed to the thread. Did this job this morning without any hassle at all |
27th Oct 2024 1:52pm |
IRBails Member Since: 25 Jan 2016 Location: Shellharbour;NSW Posts: 9 |
Just picked up 4 of these, My son in law has a Cat dealership so a cheap solution. I had the vitron, although the bearing service may not have supplied vitron, and found that the O rings went hard and leaked after 10,000 k's. The cat O rings are Blue and are not rubber, also have a high temp and pressure rating. So will have to do the replacement and see if this resolves my leak. My car is L494, purchased new 2016 and now has 230,000 k's. Have had a good run , I tow a large van, best tow vehicle one can have IMO. Hope the update re O rings helps some one as much as this thread has helped me. |
7th Nov 2024 4:16am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
Well, decided to do my o rings yesterday as I had the oily smell. Managed to overtighten the securing bolt and snapped it off so a new oil cooler has been ordered.
16th Nov 2024 9:21am |
Well managed to get it done before the weather set in. With the excellent thread over in the wiki, it wasn’t too bad a job. Managed to butcher an electrical connector but otherwise reasonably straightforward and if there were a next time, I’d probably be able to do it an afternoon.
23rd Nov 2024 10:14am |
