Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 37 of 37 <123 ... 353637
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Are you sure the leak is not the pipe at the rear of the oil cooler? That’s a common place to leak.
Post #692199 8th May 2024 9:25pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Yes, the turbo oil feed is all dry. I think previously the rings were changed. Because I can see that someone undid the oil cooler gaskets from unmatched bolts which are on now. 2011 Vogue SE 4.4 TDV8
Post #692211 8th May 2024 10:01pm
LRworkhorse
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Garymcduff1 wrote:
Hi all, came across this forum whilst trying to research/locate an oil leak on my 2013 4.4 sdv8.i had the oil cooler gasket replaced back in December 2021 and all was well until about 6 months when an oil leak was noticed on a service. I got what seams to be an intermittent oil leak towards the front of the engine somewhere between the throttle body and drivers side valve cover, it can go days with no leak, then a slight leak and then lots dripping from everywhere under the drivers side of the engine, when it leaks it's also spray oil up onto the engine cover (lots of oil it's soaked) and the bonnet when cover removed. I've check all inlet pipes, egr, valve cover and anything else that can be tightened and tried looking for it whilst putting the car through different rev ranges but can't locate it. Not sure if it's related but when driving if I drive hard enough for the secondary turbo to kick in it blows a puff of blue smoke, but once the smoke has cleared i can continue to drive hard and no smoke. I don't think the oil leak is a turbo seal as the amount it's losing I'm sure the tailpipes would be constantly pumping out blue smoke so wondering if anyone has experienced this and have any ideas what's going on as I'm completely stumped now.
Did you find a fix to this mine is leak oil in the same area front of top engine bay
Post #693267 24th May 2024 7:56pm
Mfcetin
After 2000 km trip, I have a lot of oil on the engine cover where the throttle body is. Before the trip I put 3 o-rings on the air inlet connection to the throttle body, as described on this forum.
It looks like oil was squirting around as it has reached innner side of the bonnet.
Is there anything else in this area which can spray oil all over the place?`
On the weekend I will undo the air intakes and have a better look. 2011 Vogue SE 4.4 TDV8
Post #693565 29th May 2024 2:46pm
fredd589
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Hi all, I checked mine this morning after noticing oil on the bottom of the undertray - no smell or dripping but is obvious if you look around the engine.
The oil cooler was replaced 6k miles ago but I'm not sure if the o-rings where done at the time, it looks a bit sticky - would you suggest replacing them? Cheers!
Post #694747 20th Jun 2024 8:38am
Mfcetin
Hi all,
I recently changed oil by draining from the pipe on the oil pan. I am pretty sure I pushed in that quick connector as much as I could but It is very slowly leaking.
I guess there is o-ring in the quick connector which I could maybe replace? Does anyone know the size or a partnr for it?
thank you all 2011 Vogue SE 4.4 TDV8
Post #695902 10th Jul 2024 1:47pm
fredd589
How have people managed to tighten the 14mm bung on top of the oil cooler?
This one to be exact -
I've managed to get to it, but I can't get a 30CM allen key that far down, and I'm not sure a socket will fit?
Cheers!
Photo credits to nino_nino!
Post #698082 14th Aug 2024 7:12pm
pcourtney
is it this one shown below - go to nino nino post 28th May 2019 for more info
the nut in my photo below is just in the way of unscrewing the plug on top of the oil pump Sad
https://www.fullfatrr.com/forum/topic45765-30.html
Item 3 on below diagram
Post #698088 14th Aug 2024 7:44pm
fredd589
Cheers!
Just a quick update to say I managed to get access to this and (hopefully) seal it all up! I took the throttle body off in the end, which was the easiest way of getting a long 3/8 extension down as with the TB off it's almost straight down.
With a 14mm hex socket - it was a tight fit but I managed to feel the socket onto the plug by feeling just behind the idler pulleys, and then sealing it up.
Went out for a bit of a drive today and it was still dry when I got back so fingers crossed!
Post #698301 18th Aug 2024 2:29pm
