Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 316 |
Are you sure the leak is not the pipe at the rear of the oil cooler? That’s a common place to leak. |
8th May 2024 9:25pm |
LRworkhorse Member Since: 24 May 2024 Location: Hamble Posts: 5 |
Did you find a fix to this mine is leak oil in the same area front of top engine bay |
24th May 2024 7:56pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 61 |
After 2000 km trip, I have a lot of oil on the engine cover where the throttle body is. Before the trip I put 3 o-rings on the air inlet connection to the throttle body, as described on this forum.
29th May 2024 2:46pm |
fredd589 Member Since: 24 Apr 2024 Location: Cambridge Posts: 10 |
Hi all, I checked mine this morning after noticing oil on the bottom of the undertray - no smell or dripping but is obvious if you look around the engine.
20th Jun 2024 8:38am |
Hi all,
10th Jul 2024 1:47pm |
How have people managed to tighten the 14mm bung on top of the oil cooler?
14th Aug 2024 7:12pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 779 |
is it this one shown below - go to nino nino post 28th May 2019 for more info
14th Aug 2024 7:44pm |
Just a quick update to say I managed to get access to this and (hopefully) seal it all up! I took the throttle body off in the end, which was the easiest way of getting a long 3/8 extension down as with the TB off it's almost straight down. With a 14mm hex socket - it was a tight fit but I managed to feel the socket onto the plug by feeling just behind the idler pulleys, and then sealing it up. Went out for a bit of a drive today and it was still dry when I got back so fingers crossed! |
18th Aug 2024 2:29pm |
