Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 2 of 38 <123 ... 363738>
Baltic Blue wrote:
Thanks Craig,pity you are not local to me or I would be your next customer.
Do you mind if I print out topic and show it to my MD next service (included in 2yr approved guarantee package)?
Don’t mind at all sir... Thats what the forum is here for Bow down Thumbs Up
Post #370829 6th Feb 2016 9:20am
GraemeS
Australia
O-rings are measured by their ID and cross-section, in mm for metric sizes. I expect the CS to be either 1.78 mm or 2.62 mm as the next size up is 3.53 mm which looks too big from your pictures. ID from the pictures looks to be 9.25, 10.82 or 12.42 in CS 1.78 or 9.19, 10.77 or 12.37 in CS 2.62. If outside these ranges then I'll post the other nearby sizes. Standard imperial sizes in small o-rings are either 1/8" CS or 3/16" CS. Hopefully your box of o-rings shows whether you used an imperial or metric size.
Post #370861 6th Feb 2016 12:01pm
Baltic Blue
Would Dan be aware if new pipes have different type seals and how much?
Post #370889 6th Feb 2016 2:51pm
GraemeS
Australia
Part# LR033343 costing 100+ GBP excl VAT plus the work to change it doesn't seem a good alternative to replacing 2 o-rings. I haven't found any reference to the reason for the new part# but perhaps the seals are visibly different.
Post #370940 6th Feb 2016 7:26pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Now this is a good thread Cam-Tech-Craig ( Top man once again ) - Thumbs Up
I am going to order the part in question from LR in the week.
2 main reasons
1. I wanna see what size the O-ring is BRAND NEW / UN-USED ( measure it )
now by measureing it - I am going to take it to a specialist O-ring supplier in the UK and get the part number/what O-ring it is - they will have the proper kit to measure it and identify it.
2. To see if the new LR part has been modified along the way ? - ie v1 or v2 etc....
Once I have found the O-ring in question - I will report back and let everyone know
A) The product code of this O-Ring
B) Where to get them from - contact details
C) How much
having said that once we find this O-Ring part - I would suggest that you change it every 20K or so - as it seems to be a very important bit - and from what I have read above - its a 1 hour job if that
again nice one Cam-Tech-Craig
Post #370951 6th Feb 2016 9:14pm
GraemeS
Australia
A great offer Emirates777 - thanks. However if the o-rings have been upgraded to Viton then they should withstand the heat for a far greater time.
The pipe is the top one in the picture.
Post #370973 6th Feb 2016 11:09pm
EmiratesA380
GraemeS
TOP MAN !!!! Thumbs Up
Now we are on the case...
Tell me can you get theses Vinton O-Rings at source ?
Or are you saying this is what we need to get ? - Vinton over the OE ?
I am going to have a word with one of the Boeing engineers when I can get my hands on the OE FFRR O-ring.
Im starting to think if they are used by Boeing in any component - then they will be excellent for a FFRR
But Thanks GraemeS good pic of the part - that's made it clearer for us all to see.
Post #371011 7th Feb 2016 9:37am
EmiratesA380
Can someone point out so we all know EXACTLY where we are looking?
Ie - Arrow C ???
PLEASE IF YOU KNOW REPLY BACK - DON'T REPLY IF YOUR UNSURE - AS IT WILL CONFUSE EVERYONE
Thanks
Post #371039 7th Feb 2016 12:16pm
Baltic Blue
A Safari search for Viton Orings brings up Viton-Orings.co.uk
They are based in Derby.
If they have a minimum order quantity.
I am in for 2 or 4.?
Post #371045 7th Feb 2016 12:39pm
EmiratesA380
Please can some who knows answer the question that has been posted !
thank you
Post #371130 7th Feb 2016 7:07pm
EmiratesA380
Post #371137 7th Feb 2016 7:25pm
GraemeS
Australia
C/D in your picture, just slightly off-centre. The pollen filter housing is huge (the full width of the engine) so when its removed (just 2 nuts) there is easy access over the rear of the engine once you climb on top although a mirror is required because the pipe bolt faces forwards.
Bearing suppliers and engineering suppliers can usually order single Viton o-rings once the size is known. There are several o-ring compounds but Viton is the popular one for high temperatures where petroleum products are encountered. although there are different Viton compounds too They're normally used inside gearboxes etc because standard o-rings wont survive the temperature.
Post #371138 7th Feb 2016 7:25pm
EmiratesA380
GraemeS
Thanks for coming back - this forum is like watching paint dry !!!!!!!!!\
I appreciate your reply - cheers Thumbs Up
Post #371139 7th Feb 2016 7:28pm
EmiratesA380
GraemeS
Now how do we find the correct size - is it we buy a unit and get one off - or does someone on here KNOW THE SIZE.
Post #371140 7th Feb 2016 7:32pm
GraemeS
Australia
Having one from a new pipe would be good although it may have already been stretched. I assume that Craig chose one that fits snugly without too much stretch, so measuring another should allow its size to be accurately identified. O-rings have standard sizes so the next size up or down wont do the job.
Start with measuring the cross-section as ID sizes are different for different CS.
Have a look at this size chart..
http://www.prepol.com/PPE-Uploads/Oring_sizes_ISO3601.pdf
Post #371143 7th Feb 2016 7:43pm
