Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
the 24mm was amazon and its unavailable now on amazon which is annoying
1st May 2024 2:55pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 52 |
Thanks for the offer of the mounting bush remover, not doing it till later this year. -----------------------
2nd May 2024 3:47pm |
id sell you it, but i have a terrible habit of hording tools haha
2nd May 2024 3:48pm |
another day another headache, it seems LR dont actually have the brake disc shield.
7th May 2024 8:32am |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 113 |
Are your back plates rusted away where the brake shoe hold down pins locate? Is this why you want to replace them?
7th May 2024 10:20am |
unfortunately for me the discs are more or less dead and scrapped
7th May 2024 10:28am |
managed to get some range rover oem bushes for the top arms from left over stock, £150 for 4 which nis a steal compared to LR with £120 for 1, replaced all those.
10th May 2024 12:37pm |
right it seems LR are consolidating there parts into a central warehouse so who knows wtf is going on there
16th May 2024 10:29am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
A working parking brake is part of the MOT test. 2012 TDV8 Vogue (L322) |
16th May 2024 11:10am |
well someone is selling a complete rear end, which has what i need, then I guess i can refurb the other parts and sell them on, including an entire rear subframe
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 742 |
If you put it back together with the fix I suggested it will work perfectly and pass an MOT (& probably last longer than new backplates 😂) |
16th May 2024 5:00pm |
unsure if am misunderstanding you cass, but dont i need some of the old brake disk shield for it?
16th May 2024 5:03pm |
orrr i get a shield from 2009, and cut off the lip so it accepts a 360mm disc[/quote]
16th May 2024 5:11pm |
ive yoloed a disc shield from an L320, we'll see when that turns up if i can make it work.
16th May 2024 5:12pm |
