Home > Technical (L322) > much ado about rear suspension overhaul
Page 6 of 6 <123456
Epson Green
I did it with someone to put a foot on the brake. Not difficult if you have a torque wrench that exceeds the value. Knocking the lock tabs in is awkward but doable. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #693426 27th May 2024 11:09am
mgrover
Ah didn't think of that since I've got no rear brakes atm
I'll get that done and bled then get it all torqued up.
I have a 1000nm adapter so let's hope that'll work Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #693427 27th May 2024 11:12am
mgrover
Ah got the parking brake all installed and working
It jammed a few times when attempting it.
The unjam procedure from gap didn't unjam it to the point it worked
In the end I more or less pulled on the cable end while running on the unjam procedure.
After doing that for both sides and reassembling it now seems to be calibrated and working properly without any horrible noises
I'll run bed in procedure when it's all sorted. Its actually a sport Sad
Post #693462 27th May 2024 10:07pm
mgrover
everythings back together finally
wheels on and boom no errors woop woop.
I do need bleed the brakes
given its an empty system it'll be a standard gap iidtool bleed
i was wondering though when it asks to pump the pedal, if a power bleeder will do? Its actually a sport Sad
Post #693496 28th May 2024 4:12pm
Epson Green
Two person pedal pumping worked for me👍 Kevin
Post #693498 28th May 2024 4:18pm
mgrover
i guess i wanna try to make this a man 1 jobo. Its actually a sport Sad
Post #693499 28th May 2024 4:31pm
mgrover
shes up and around after the brake bleed
was a bit of race against time since bleeding via gap needs battery and mine wasn't fully charged so it died a few times and had to restart the process.
i ended up not using the power bleeder when bleeding via gap then going around and doing the normal bleed, not much air came out in this bleed which one would assume the gap bleed did a good job.
would be handy if i could just purge for example front left via gap rather than the entire process but ah wells.
one of the bleed nipples was actually so blocked with salt i had to drill the salt out once i removed the nipple.
the backend feels amazing, no knocks or anything, now looking at the crusty front end am thinking maybe time to do that as well but i think id rather just enjoy the car again, its been a few months off the road.
got some AT3s coming friday, she needs a full wheel alignment and the wheels need a full blast and respray.
just wanted to say thanks for all the help along the way Smile Its actually a sport Sad
Post #693607 30th May 2024 7:24am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Thank you for sharing your journey, it is most enlightning to see how people go about these jobs.
Will
Post #693709 31st May 2024 8:39pm
mgrover
i always think it best to document any little tid bits that aren't in the service manual.
hopefully it shows up for the next person doing it in search and makes their life easier. Its actually a sport Sad
Post #693726 1st Jun 2024 11:45am
Page 6 of 6 <123456
