Home > Technical (L322) > much ado about rear suspension overhaul
Page 4 of 6 <123456>
mgrover
the 24mm was amazon and its unavailable now on amazon which is annoying
it was this
https://www.amazon.co.uk/dp/B0CQHPVF3Y?psc...ct_details
if you'd like, you can just come borrow my kit. you'd need an M16 x 2.0 threaded bar but thats about it.
i have a ton of m16 nuts handy as well that go with it. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #691702 1st May 2024 2:55pm
mgrover
the M16 bolts/nuts turned up for the upper control arm bushes, problem is they won't fit the pre-existing holes in the subframe and I really don't want to drill them out because thats just a ridic thing to do imo
at this point am unsure whether to speak to AF and get the other fitment and hope they aren't M16 bolts as well or just use M14 bolts anyway? Its actually a sport Sad
Post #691752 2nd May 2024 11:37am
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Thanks for the offer of the mounting bush remover, not doing it till later this year. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #691767 2nd May 2024 3:47pm
mgrover
id sell you it, but i have a terrible habit of hording tools haha
whenever you wanna do it just give me a shout and its yours for as long as you need it. Its actually a sport Sad
Post #691768 2nd May 2024 3:48pm
mgrover
another day another headache, it seems LR dont actually have the brake disc shield.
which is defo not good since this cars useless without it Its actually a sport Sad
Post #692047 7th May 2024 8:32am
Epson Green
Are your back plates rusted away where the brake shoe hold down pins locate? Is this why you want to replace them?
I had the same problem earlier this year - no stock of the 2010 - 2012 brake back plates anywhere. And the pre 2010 don’t fit, they are too small to go over the later larger brake disc.
In the end and after research on the forum I found a useful work around using the old type brake shoe hold down washers on the back of the back plate. I filed a round hole approx 5mm in the back for the depression in the hold down washer to sit in so as not to over tension the hold spring. I works great. Handbrake operation is perfect. Not ideal but it works.
https://www.ebay.co.uk/itm/301149953974?var=600235200733
 Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #692056 7th May 2024 10:20am
mgrover
unfortunately for me the discs are more or less dead and scrapped Sad
but a breaker got back to me today, £40 they said, so if they are in good condition ill be buzzing Its actually a sport Sad
Post #692058 7th May 2024 10:28am
mgrover
managed to get some range rover oem bushes for the top arms from left over stock, £150 for 4 which nis a steal compared to LR with £120 for 1, replaced all those.
i noticed the none stock one needed pressing the whole way while stock ones you can gently tap in and only need to really press the last few mm.
now its a few coats of hammerite for everything and away we go
also installed the borg & beck CV joint. the snap ring was way too big from them so ended up just using the oem ones.
nicely coated as well and just waiting reinstall, probably really also work doing the diff seals whilst everything is out. Its actually a sport Sad
Post #692302 10th May 2024 12:37pm
mgrover
right it seems LR are consolidating there parts into a central warehouse so who knows wtf is going on there
currently I am tempted to just put it back together without a parking brake.
then put it all together(probably will next to cut the new discs) when they finally turn up
anyone know if that'll fail an MOT? Its actually a sport Sad
Post #692771 16th May 2024 10:29am
JayGee
A working parking brake is part of the MOT test. 2012 TDV8 Vogue (L322)
Post #692774 16th May 2024 11:10am
mgrover
well someone is selling a complete rear end, which has what i need, then I guess i can refurb the other parts and sell them on, including an entire rear subframe
orrr i get a shield from 2009, and cut off the lip so it accepts a 360mm disc Its actually a sport Sad
Post #692775 16th May 2024 11:10am
cass
If you put it back together with the fix I suggested it will work perfectly and pass an MOT (& probably last longer than new backplates 😂)
Post #692798 16th May 2024 5:00pm
mgrover
unsure if am misunderstanding you cass, but dont i need some of the old brake disk shield for it?
i currently have no part of them at all?
or does your fix mean i dont need it at all? Its actually a sport Sad
Post #692799 16th May 2024 5:03pm
Epson Green
orrr i get a shield from 2009, and cut off the lip so it accepts a 360mm disc[/quote]
I think this would work👍👍 Kevin
Post #692800 16th May 2024 5:11pm
mgrover
ive yoloed a disc shield from an L320, we'll see when that turns up if i can make it work.
plus its like a £30 punt vs £80 for 2009 or £150(wtf LR) for the original part. Its actually a sport Sad
Post #692801 16th May 2024 5:12pm
