![]() | Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
So I've got that BMW subframe kit. Thought the receiver end would work.
question for when I get to installing the bearings.
did what I could with the wire wheel of death and a dremel afterwards. a nice glug of neutrarust onto most of the knuckle.
Hmm calipers needing refurbing as well.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
This looks like a useful piece of kit, what is it?
15 tonne hydraulic puller.
out of all my terrible skills,
the hammerite got on there well enough should have maybe tapped off any holes but what ya gonna do.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
Is it possible to "modify" the brake guard, i.e. cut a bit out to be able to fit it afterwards, I have done this for the front brake disk guards but I have not looked if you can also do it for the rears.
you can, but the way i see it its £150 vs £34.
well shes stripped down again to just a separate hub and knuckle with 1 bearing destroyed.
well thats one knuckle almost sorted,
while waiting on bits and bobs decided to start the rear subframe bushings. only did left side
