![]() | Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
the 24mm was amazon and its unavailable now on amazon which is annoying
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 ![]() ![]() ![]() |
Thanks for the offer of the mounting bush remover, not doing it till later this year. -----------------------
id sell you it, but i have a terrible habit of hording tools haha
another day another headache, it seems LR dont actually have the brake disc shield.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
Are your back plates rusted away where the brake shoe hold down pins locate? Is this why you want to replace them?
unfortunately for me the discs are more or less dead and scrapped |
managed to get some range rover oem bushes for the top arms from left over stock, £150 for 4 which nis a steal compared to LR with £120 for 1, replaced all those.
right it seems LR are consolidating there parts into a central warehouse so who knows wtf is going on there
A working parking brake is part of the MOT test. 2012 TDV8 Vogue (L322) |
well someone is selling a complete rear end, which has what i need, then I guess i can refurb the other parts and sell them on, including an entire rear subframe
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
If you put it back together with the fix I suggested it will work perfectly and pass an MOT (& probably last longer than new backplates 😂) |
unsure if am misunderstanding you cass, but dont i need some of the old brake disk shield for it?
orrr i get a shield from 2009, and cut off the lip so it accepts a 360mm disc[/quote]
ive yoloed a disc shield from an L320, we'll see when that turns up if i can make it work.
