Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 10 of 14 <123 ... 91011 121314>
@rangerover.1971
Congrats on the purchase and all the effort to get it running again. You have the skills, equipment and space I sadly lack! Being in London I’d have to have a petrol and the LR specialists I spoke to advised against the 5.0 S/C. Being so few of them around means garages aren’t used to working on them and an estimate for the timing chain job is £4-6k. So I’m keeping my eye out for a good 4.2 S/C.
For corrosion treatment and protection I suggest you check out Bilt Hamber products. I settled on them for my 1971 RR.
Thanks for all of the detailed posts - made for interesting reading. 1971 Suffix A Range Rover
1985 Mercedes W123 230E
2011 Range Rover 4.4 TDV8 Vogue SE
2014 BMW 535i Lux
2015 BMW i3 Rex
2018 BMW R1250 GS
Post #677267 4th Nov 2023 6:57pm
dhallworth
Replaced both MAF’s and put 2 new air filters in today. The filters weren’t bad but they weren’t new.
I then fitted the new MAPT sensor that lives on the back of the charger cooler.
After that I had a go at changing the oxygen sensors. On the 4.2 the down pipes bolt straight to the manifold so when I did the oxygen sensors on that I took the two bolts out of each side and dropped the front of the exhaust for access.
On the 5.0 there is a separate, very short piece of pipe that bolts to the manifold and the down pipes bolt to that meaning that the oxygen sensors are almost in the manifold at the cylinder head.
The drivers side one came out no problem using a 22mm open ended spanner. I replaced that and all was good.
I looked up at the passengers side one and it was obscured above the front propshaft. I dropped the ramp down and with the pollen filter removed could see the sensor from the top. I tried with the spanner but it was solid. Normally at this point I’d just cut the wires and use a long 22mm socket but I was trying to save these sensors so I went to Halfords and bought an oxygen sensor socket.
When I tried the new socket it started to slip and turn the edges of hex on the sensor. At this point I stopped, went into the house and got the car key, started the engine, left it running for 15 mins to get some heat into the exhaust and then cut the wires off the sensor before slipping the 6 sided socket over the top. Thankfully, at this point the sensor unscrewed without damaging the threads! I’ve left refitting the new one till tomorrow when everything has cooled down though!
The Bank 2 sensor which is the one with the -12.5% fuel trim does look much cleaner then Bank 1. It looks red in this picture but that was taken just after the car had been running for 15 mins.
The MAP sensor at the very front is situated under the vacuum solenoid on the front of the supercharger. To get to that normally you’d need to drain the cooling system. However, thankfully cutting a 1/4” T30 in half and putting it in a tiny spanner worked a treat.
One thing I did notice when I removed the PCV pipe was that there was oil in it. That’s strange as I replaced both PCV valves when it was in pieces.
The PCV valve on these comes in 3 pieces. A diaphragm, a spring and a plastic cap that you build into the valve cover. I’m now wondering if I’ve nicked a diaphragm causing it to leak and that’s what could be causing my issues. Problem is you can’t remove the plastic cap from the valve cover without breaking it so I’m going to order 2 new ones and see. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #678315 19th Nov 2023 11:04pm
Getting there David, I recon you would have noticed damaging the PCV valve but worth a check I suppose... Thumbs Up Pete
Post #678319 20th Nov 2023 8:56am
dhallworth
Decided against ordering PCV valves. I don’t think I’d have been able to clip them back together if I’d have damaged them.
Just waiting for the symposer bung that lives on the rear of the supercharger to arrive from LR and I can get the car back together.
Land Rover are moving warehouses at the moment, they’re quoting up to 10 days for delivery of parts, local dealer says they’re seeing about 3 days so hopefully it arrives this week as we’re going away for the weekend and I really want to take the car with us.
Post #678405 20th Nov 2023 11:54pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
David - I'm pulling one of the banks apart on my 5.0 S/C at the moment as I seem to have a faulty injector that's flooding no 4 cylinder - is there a trick to getting the fuel rail off, or just lots of pulling to free things up and pop it off the seals on the top of the injectors?!
Thanks,
Paul
Post #679172 30th Nov 2023 6:00pm
dhallworth
Evening Paul, apologies for my delayed response.
Once you have removed the 4 (I think it’s 4 from memory) bolts that secure the fuel rail to the cylinder head, the fuel rail should be free to come off.
One of mine pulled off fairly easily, the other one I used a pry bar to very gentle lever against and it came off.
Post #679252 1st Dec 2023 7:51pm
paulbrown22
Not at all, many thanks for responding!
Understood - I've so far been reluctant to pry given the apparently fairly delicate valve covers, but might have to put some protection on them and have a go. I've tried pulling with all sorts of things wrapped around the fuel rail at both ends, but it just doesn't want to pop off (with all 4 bolts removed!) despite a bit of movement. I also have a slide hammer with jaws arriving at the weekend as another option to try.
There seems to be a massive range looking on Youtube and here - some rails just lift off, on others people are using engine cranes, ratchet straps, telehandlers, etc. to apply upwards pressure they are so stuck! Hopefully mine isn't quite that bad...
Post #679258 1st Dec 2023 9:03pm
dhallworth
If it helps, you pull them towards you and up at the same time.
If you put a bolt back in and look at the angle it’s sitting at, that’s the angle that you need to pull the rail at.
It’s strange that some of them are really stuck and others aren’t.
Have you got a slide hammer to remove the injectors?
Whilst you’re under the bonnet on yours, could you possible have a look down the back of the supercharger?
There’s a solenoid down there on mine with a spigot that sticks out of it. It looks odd as there’s nothing connected to the spigot. There wasn’t on mine when I got it, I just want to make sure nothing is missing.
It’s directly underneath the black plastic housing that is mounted to the back of the charger that holds the wiring loom. If you can’t see it, removing two T30 screws and moving the plastic casing out of the way will reveal it. I’ll grab a picture of mine when I’m in there tomorrow.
Thanks,
Post #679260 1st Dec 2023 9:22pm
dhallworth
Here’s the spigot that I’m not sure about. It never had anything connected to it when I bought mine but it looks as if it should have.
Post #679323 2nd Dec 2023 11:00pm
Had a look through my old pics but didn't get one there... does it blow or suck with the engine running..? Pete
Post #679331 3rd Dec 2023 9:34am
dhallworth
Not when it’s idling.
There’s an electrical connector on it so I don’t know when it’s supposed to operate.
Post #679335 3rd Dec 2023 10:39am
dhallworth
Right, last weekend I decided that my hesitation was in fact coming from the gearbox so I started this thread here:
https://www.fullfatrr.com/forum/topic68557.html
RRPhil very kindly sent me a solenoid to fit to the EDS2 position on the valve body to see if it was a solenoid issue or a torque converter issue so last night I set about doing the work!
When peering around the gearbox I noticed that someone has definitely been in at it before. It was also an aftermarket sump that was fitted, not a genuine ZF one. The ZF ones are made by Filtran and have the logo stamped onto them along with a date on the inside. This one had nothing.
Once the sump was removed the valve body became visible.
Once the valve block was removed, there’s a surprising amount of space in the bottom of the gearbox.
If you zoom in on the picture above you can see how flat the 4 round tube seals have become. I replaced them along with the bridge seal at this point. You can see the new seals that protrude from the housing.
Once that was done I had a good look at the valve body on the bench.
After removing 6 bolts, the gearbox ECU can be removed from the valve body.
The solenoids are then held into the valve body by a metal bar with 8 T27 bolts securing it to the valve body.
Once the bar is removed the solenoid can be removed by gripping it firmly and pulling.
Building everything back up was fairly straight forward too! Once the valve body was back in the car I fitted the new electrical sleeve and put the sump back on. The old electrical sleeve was dated 0112 so it was obviously the original for the car. I’m surprised it wasn’t leaking!
The original plan was to put the old oil back into the gearbox as it was serviced 40k miles ago but when draining it and looking through it with a torch it was still opaque but it was dark. Then when I saw it in the bucket I couldn’t bring myself to put it back in so the gearbox was filled with fresh Lifeguard 6. Thankfully, there was just enough left in my 20 litre tub from when I sorted the box on the old 4.2SC.
New oil v old oil!
I filled the gearbox with an oil syringe with the car switched off then refitted the fill plug loosely. I then started the car and continued to fill the gearbox until there was a small flow of oil coming out of the filler plug. Once that was done I left the car running and cycled through the gears until the oil temperature was 40 degrees. I then removed the fill plug once more and then let the fluid run out until it slowed to a trickle then torqued the fill plug to spec and refitted the heat shield.
By this time it was 23:00 (I had unlocked the workshop to put the car inside at 20:00) so I took the car out for a drive. The gearbox was smooth before but it’s like silk now. I stopped just before the junction to the dual carriageway in the village and started graphing the transmission outputs.
The turbine speed sensor and the engine RPM sensor are now much more in sync with each other, the car is locking up in the gears properly and the hesitation I was experiencing before is now resolved. It’s driving like a different car.
I’m now going to drop the sump once more and replace the full set of solenoids as per RRPhil’s advice. This will also allow me to return the solenoids he sent me so that he has them back in stock in case and forum member needs help in the future.
I’m really, really pleased now as I had visions of removing the gearbox over the Christmas holidays.
Post #679788 8th Dec 2023 11:11am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Glad you’ve finally resolved the hesitation, David. I’d be tempted to leave it as is if it’s all running well!
Post #679827 8th Dec 2023 7:17pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
A great read as usual, many thanks David
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #679851 9th Dec 2023 1:25am
dhallworth
It was the little guys 1st birthday today so we did a bit of running around ferrying the in-laws about so I decided I’d use the Range Rover.
When I got onto the dual carriageway the gear change was perfect and it was locked up instantly on the road. It genuinely was like driving a different car. I’d even go as far as saying it was the first time I’d enjoyed driving the car since doing the timing chains.
On the motorway there was an odd drumming noise coming from the car. It was from the rear left corner. I had a funny feeling that it was likely to be a sticking rear caliper. This was confirmed when I got to Paisley and felt the rear left wheel to find it hot whereas the others were all stone cold.
I came home via the back roads to keep the speed down but when I got home noticed that the wheel was cold. A quick trip to Port Glasgow for some juice for the party which we’d forgotten followed by a run straight back up the dual carriage and it was still cold so it looks like the caliper has dropped off. I think I’ll strip it and clean it up and see if I can get a seal kit for it seeing as the rear calipers on these do have a habit of seizing.
I was convinced that the hesitation was engine related, especially given all the work I’d done under the bonnet when doing the timing chains. However, I’m quite chuffed that it wasn’t as it means I didn’t get anything wrong Very Happy
Only thing left to do now which is going to wait until next year is undersealing and rust proofing. There’s zero rust anywhere on this car and that’s the way I’d like it to stay!
Post #680034 10th Dec 2023 10:49pm
