![]() | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Happy birthday to your little man David... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8537 ![]() ![]() ![]() |
Top job, should be sorted for a while now...
Great job David “as ever”
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3197 ![]() ![]() ![]() |
I decided I’d had enough of the festivities today. Cheryl went to meet her pal and her kids at soft play and she took Matthew with her so I had an afternoon to myself. I decided I’d get the dampers and solenoids swapped out in the valve body on the Range Rover gearbox.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
Excellent David - I'll be following that when I do mine in the Spring. Thanks for all the information and parts suppliers. Gavin
Done 90 miles in the car now, most of which has been done on A and B roads to afford the car as many opportunities to change gear as possible. The gear change on it is now silky smooth. Since doing this, I’ve not felt a single change, you can hear the engine note change and you can see the revs change, other then that you can’t tell what the car is up to |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Great news and long may it continue! |
Daz90 Member Since: 12 Nov 2023 Location: Bristol Posts: 40 ![]() ![]() |
Awesome! |
Well done David... I recall those 6HP gearboxes always felt "value for money" whenever serviced... |
Thanks guys |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Just finished reading this thread, very jealous of how handy you are! I've bought an L322 5.0 S/C myself yesterday. The chains are already done on mine, but I think I'm experiencing the same problems with the gearbox as you did.
Mine was hesitating in 3rd gear at around 1500 - 2000rpm when being driven gently. If you gave it more throttle then the hesitation stopped.
Thanks for the video. I sold my 2017 L405 S/C last year. I'm talking about a 2010 L322 5.0 S/C with the ZF 6 speed gearbox. I'm currently in the process of getting it on the road here in Belgium and will drive more after all of that is sorted. '17 Range Rover 5.0 Supercharged AB (Sold)
Pleased to report that after dropping it off this morning, the RR has sailed through its MOT with no advisories.
