Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 14 of 16 <123 ... 13 141516>
dhallworth
Not for my wallet though Laughing
TPMS initiators have arrived this morning so fingers crossed I can get the whole thing sorted tonight now.
Post #707507 23rd Dec 2024 3:56pm
dhallworth
Car is now back out of the workshop!
TPMS system is retrofitted. Full guide here: https://www.fullfatrr.com/forum/topic72111.html
AHB Mirror is retrofitted. The settings needed in the CCF for this to work are weird...
Auto High Beam 1 - Needs to be "Fitted"
Auto High Beam 2 - Needs to be "Disabled"
Auto High Beam 3 - Needs to be "Rest of World"
I had option 3 set to "UK" but it wouldn't work. The auto light came on with the ignition on but went off as soon as the engine was started. I changed it to Rest of World tonight and am pleased to report that it's working perfectly.
Rear brakes rebuilt in their entirety and the handbrake bedding in profess has been completed.
Tonight I also gave it an oil and filter change and a good once over for it's MOT in January. I balanced all of the wheels after fitting the TPMS sensors. None of them needed much weight but it's amazing how much difference it makes when you balance your wheels every 12 months.
Here's hoping for a nice clean MOT pass and another 12 months of fairly trouble free usage!
Post #707553 24th Dec 2024 1:49am
Top job as always, lets hope that's the last thing you have to do before the warmer weather starts....!! Bow down Bow down Pete
Post #707587 24th Dec 2024 6:32pm
CaifanSC
United States 2012 Range Rover Autobiography 5.0 SC V8 Epsom Green
David, amazing read! I'm going through both threads; for this car and the black supercharged Rangie you had.
With your experience so far, I'm really interested in your recommendations for rust proofing the subframes.
I just did an oil change on my 12 AB, which hasn't really had a hard life, and I noticed bad rust on the front subframe. It doesn't even have 100k on the clock, and I've put less than 20k miles in the last 5 or 6 years. So, I'm in the process of looking for a spare subframe that will get the extreme treatment for the future.
Keep up the great work! Very inspiring. 2012 Range Rover Autobiography
91 BMW 850i 6 speed
94 BMW 850 CSi 6speed
Supercharged Tbirds
Audi S8, Audi V8 Quattro
Post #708102 2nd Jan 2025 3:04pm
dhallworth
When I did my subframe it was a lot of work. Painting with the 2 part epoxy mastic was hard work as the paint was heavy and it killed brushes.
I keep looking at this one on eBay:
https://www.ebay.co.uk/itm/126754279401
It's been acid dipped, galvanised and then powder coated. I'd be sorely tempted to go down that route if I was doing it again. The only thing that put me off it before was the idea of having to re-tap the holes for any mountings and the holes for the bushes being slightly smaller after it was done.
Longevity wise, I sold my 4.2 and bought the 5.0 after just 1 winter so can't really comment on how the Bilt Hamber products were holding up.
Post #708145 2nd Jan 2025 10:18pm
dhallworth
The 5.0 hit a milestone on Tuesday morning.
Given the weather we've had recently the RR has had a lot of use. It's desperate for a wash now. MOT is on Thursday and I never present a car for an MOT when it's filthy. It makes no difference to the test but I always like knowing it's clean when it's going somewhere.
Fingers crossed for Thursday. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #708890 11th Jan 2025 9:00pm
Good luck with the MOT but I doubt you will need it... Bow down Thumbs Up Pete
Post #708892 11th Jan 2025 10:11pm
dhallworth
I dropped the SC off with the local specialist for it's MOT yesterday. Whilst I was waiting to be picked up, they took the car round the corner for its MOT.
First time I've seen it on the road from the outside or heard it burble past. 13 years after the L322 went out of production it's still a good looking car in my books. Especially in the silver. I really lucked out when I found this one in silver.
Pleased to report that she sailed through the MOT without so much as an advisory. This car has never failed an MOT in its life so it's nice to be able to keep that tradition going. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #709510 18th Jan 2025 12:13am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
a well looked after and largely original L322 is indeed a lovely sight First time FFRR owner
Post #709518 18th Jan 2025 10:29am
dhallworth
Since I've had this 5.0, every time the fuel light comes on the dash shows approximately 50 miles of range but I can only get 80 odd litres in the tank. The manual states that it's a 101 litre tank so I'd expect to be able to get more then 80 lites in it when the light comes on.
After a bit of Googling, fuel gauge issues seem quite common. However, it seems to be more that it reads empty when it's full or the gauge is erratic so neither symptoms directly fit with my car.
However, it's a TSB so I'm going to give it a go and see what happens.
https://www.fullfatrr.com/gallery/albums/u...6294~1.pdf
I've ordered the crimps from LR as I've not got many left and at a quid each it's not particularly expensive. I've also ordered a new gasket for the fuel tank.
Will report back once the parts have arrived and I've had time to do it.
Post #710986 3rd Feb 2025 11:13pm
Mikey
Done hundreds of these on D4/RRS, but usually gives a 0 range when the fuel level drops a bit
Post #711048 4th Feb 2025 6:55pm
dhallworth
Hmm, I feared that might be the case.
I'll give it a try as it's an easy enough to do. Failing that, I guess it's a level sender problem and I've no doubt from Land Rover they're hideously expensive. Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #711069 4th Feb 2025 10:17pm
Mikey
If it's any consolation, I've a Jag XF that runs out of fuel at ΒΌ tank remaining. I remaining hopeful it's also an easy fix Laughing
Post #711079 4th Feb 2025 11:44pm
dhallworth
A friend of mine has a 2007 TDV8 that does exactly that! I've got enough problems of my own without taking on other peoples issues at the moment. Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #711287 7th Feb 2025 12:26am
camaro8199
United States 2010 Range Rover Supercharged 5.0 SC V8 Santorini Black
How did you remove the supercharger. I have mine loose and tilted but am hung up in the back by something. Can you tell me what needed to be unhooked in the rear?
Post #713273 4th Mar 2025 4:10am
