Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 3 of 16 <123 4 ... 141516>
I always seem to buy cars miles from home... love the pickup day, always an adventure...
Sounds like a good one with a bit of work.... Thumbs Up Pete
Post #667363 23rd Jun 2023 11:22am
And so another adventure begins David, good luck with it. Thumbs Up
Out of interest what sort of fuel figures did you achieve? Got - 2017 SDV8 Autobiography in Loire Blue
Post #667368 23rd Jun 2023 11:58am
dhallworth
Sitting at 65 it averaged around 28mpg.
It had the restricted performance light on the dashboard and the engine management light on too so not sure if that could be doing anything to affect the economy.
Post #667372 23rd Jun 2023 12:36pm
David, mine did about that at that speed and around 20mpg around town, I always thought that was OK for the performance it offered.... Thumbs Up Pete
Post #667374 23rd Jun 2023 1:16pm
dhallworth
Thanks Pete Smile
Handy to have another to reference it against. It was using less then my 4.2 does so was quite happy at that.
Post #667376 23rd Jun 2023 1:59pm
I ask because my 3.6 was returning just over 30 on a run up to Aberdeen earlier this week , doing around 65mph and I rarely see anything over 20 around town, so it’s certainly closer than I had imagined.
Certainly food for thought Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #667381 23rd Jun 2023 3:09pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Well done David, a cracking looking car and a great adventure, looking forward to the next instalment Thumbs Up Thumbs Up
Post #667393 23rd Jun 2023 6:46pm
That's the direct injected modern petrol 5.0 Compared to the much older 4.2... The 5.0 is much more like a diesel in its design with its direct injection fuel system...
TD or V8, consumption is much closer now with the 5.0... Thumbs Up
Post #667415 24th Jun 2023 12:39am
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Looks fantastic. I would love one! Best of luck with it 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #667463 24th Jun 2023 8:56pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Really looking forward to your 'adventures' with this David - hopefully they won't be as immense as the 4.2SC.. well for us it would be really interesting but I fear for the health of your wallet Very Happy
Cheers
Gavin Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #667484 25th Jun 2023 8:50am
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Looks smart! Nice to see the proper sized reg plate too.
Slightly stunned by the MpG as well, my TDV8 was only 1mpg more than that at similar speeds
Post #667510 25th Jun 2023 2:11pm
dhallworth
I hate looking at Range Rovers with the wrong sized plate on them.
I’ll be putting my plate on this at some point but I’ve got the proper sized one that Rob at Duckworths sorted me out with.
Post #667511 25th Jun 2023 2:17pm
dhallworth
I've been thinking about this more and more and doing even more reading online, especially on the American forums...
From what I've managed to piece together, when the chain tensioners on the 5.0 start to wear you feel a misfire and will get misfire codes appear before you get a Crankshaft/Camshaft correlation fault appear.
This car has zero chain rattle and not once on the 426 mile journey home did I feel the slightest of misfires. Not even when climbing the lanes to the house at low revs.
There are no misfire codes stored either, the only code stored when I collected the car was:
Quote:
P0016-00 (EC) Crankshaft position - camshaft position correlation - bank 1, sensor 1
The seller hadn't moved the car for 3 weeks before I collected the car so it had sat for a long time without being started and it was as quiet as my XFR is when it starts.
Prior to starting it for the first time, I cleared the codes off the car and before the car had finished cranking there was a reduced performance light back on the dashboard with the same error code.
Would the car know that quickly that something wasn't right?
I've read online about the camshaft phasers giving problems and there's information out there on how to troubleshoot them. Replacing them means taking the chains off anyway so it'd make sensor to do the whole lot.
However, I'm wondering if it could be as simple as a camshaft sensor? If I swap Bank 1 Sensor 1 with Bank 2 Sensor 1, it'll be interesting to see if the fault moves with the sensor.
Post #667707 27th Jun 2023 4:18pm
dhallworth
Having had my IID tool on the car tonight monitoring the live values, I can see that there’s about a 5 degree difference between the intake cam on Bank 1 and Bank 2.
I’m convinced I could hear a little chain rattle off it tonight when it started as well.
Chain kit it is then Smile Just waiting for Rob at Duckworths to come back to me with a cost for the timing kit now.
Post #667718 27th Jun 2023 6:07pm
JamboM3
I guess it’s best to get that out the way now, been following a guy in the US doing the replacement and he has had a nightmare with it.
Prevention is key Thumbs Up
Post #667745 28th Jun 2023 12:08am
