Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3057 |
Replaced both MAF’s and put 2 new air filters in today. The filters weren’t bad but they weren’t new.
19th Nov 2023 11:04pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8149 |
Getting there David, I recon you would have noticed damaging the PCV valve but worth a check I suppose... Pete
20th Nov 2023 8:56am |
Decided against ordering PCV valves. I don’t think I’d have been able to clip them back together if I’d have damaged them.
20th Nov 2023 11:54pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
David - I'm pulling one of the banks apart on my 5.0 S/C at the moment as I seem to have a faulty injector that's flooding no 4 cylinder - is there a trick to getting the fuel rail off, or just lots of pulling to free things up and pop it off the seals on the top of the injectors?!
30th Nov 2023 6:00pm |
Evening Paul, apologies for my delayed response.
1st Dec 2023 7:51pm |
Not at all, many thanks for responding!
1st Dec 2023 9:03pm |
If it helps, you pull them towards you and up at the same time.
1st Dec 2023 9:22pm |
Here’s the spigot that I’m not sure about. It never had anything connected to it when I bought mine but it looks as if it should have.
2nd Dec 2023 11:00pm |
Had a look through my old pics but didn't get one there... does it blow or suck with the engine running..? Pete
3rd Dec 2023 9:34am |
Not when it’s idling.
3rd Dec 2023 10:39am |
Right, last weekend I decided that my hesitation was in fact coming from the gearbox so I started this thread here:
8th Dec 2023 11:11am |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 119 |
Glad you’ve finally resolved the hesitation, David. I’d be tempted to leave it as is if it’s all running well! |
8th Dec 2023 7:17pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 561 |
A great read as usual, many thanks David
9th Dec 2023 1:25am |
It was the little guys 1st birthday today so we did a bit of running around ferrying the in-laws about so I decided I’d use the Range Rover.
10th Dec 2023 10:49pm |
