![]() | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8491 ![]() ![]() ![]() |
David,
Thinking about it it's got to be the calliper on the discs. If I drive mine a lot on adaptive the rear wheels are covered in brake dust as much as the fronts.... Pete
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3176 ![]() ![]() ![]() |
The calipers are nice and free though, it's really weird.
Maybe the handbrake is sticking slightly and the extra heat created from the rear braking with cruise isn't helping...!!!
Ordered handbrake cables from the JLR Classic Parts website on Monday afternoon and they’ve just been delivered by DHL.
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
Maybe check the park brake shoes retaining pins are holding in the backplates properly if it has that setup . Older type pin washers can be fitted on the pins . Kits can be found on eBay and Amazon |
Thanks for the pointer. |
Another trick is to partially fold a suitable size washer over the shoe retaining pin if the correct washer is not available. The retaining pin should be orientated to remain secure |
Finally managed to get some time on the Range Rover this weekend after waiting for aaagggeeessss for my parts to arrive.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 609 ![]() ![]() ![]() |
I agree with you David, but I found I needed to react quicker than I expected when a tyre delaminated. I had the TPMS flash up a warning on a normal A road at something like 23psi. It was then going down ~2 PSi every second and I had to spot somewhere and get relatively safe off the carriagway in a few seconds. I was lucky and found a wide driveway to change the wheel in but, as I say, just luck that that came up so soon after the warning. Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
Rear callipers went on my S/C, I think it's relatively common.
Car is now rebuilt.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 978 ![]() ![]() |
Epic, well done |
Nice Christmas present for it.... |
