Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Thanks for your reply - do you have a website to order from? |
16th May 2022 9:27pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Send me a PM and will be in touch tomorrow. |
16th May 2022 9:38pm |
@JNC
21st May 2022 5:24am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Waking up the thread, hoping someone can help me diagnose exactly what has failed on my driver's heated/cooled seat.
29th Jun 2022 10:30pm |
If anyone needs a complete assembly - https://www.ebay.co.uk/itm/313963553273 Jaguar part number but visually the same as the LR one |
6th Jul 2022 7:36pm |
28capridave Member Since: 08 Nov 2020 Location: stockport Posts: 24 |
I first thought mine was the base peltier but it turned out to be the ducting in the seat backrest fitted a new one and back to fully working, a lot of your faults I also had so always worth checking the rear ducting first as its relatively easy to get too in comparision to the base unit which I had in and out like a yoyo when I first took the rear cover off the ducting looked fine but on closer inspection it had a large crack in the plastic at the back every time the seat backrest moved sometimes it worked ok but then off again. |
24th Jul 2022 2:26pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Are these repair kits still available? I want to get on and fix the lack of cooling on my seat back. Base is OK so I suspect cracked ducting on the seat back one.... These? https://www.jnc-automotive.co.uk/product-p...repair-kit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
25th Aug 2022 10:00am |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
Heater repearing.
28th Sep 2022 5:46pm |
lesteph Member Since: 23 May 2013 Location: CACHAN Posts: 1 |
Dear,
2nd Oct 2022 10:35pm |
Roverte Member Since: 01 Dec 2021 Location: Connecticut Posts: 6 |
With the help of this thread I'm sure that I have a cracked plastic duct but I cannot get the seat disassembled to remove and inspect.
24th Oct 2022 8:49pm |
My post:
24th Oct 2022 8:52pm |
Thank you so much - that photo is exactly what I needed to be able to feel the tabs. |
25th Oct 2022 12:40am |
DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 42 |
Can anyone verify where the control module is, or even better post a picture. I have a 2012 supercharged with no sign of life at the controls and an empty compartment with connectors under the passenger seat, in the plastic covered cubby. |
13th Nov 2022 10:53pm |
13th Nov 2022 11:00pm |
