Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 26 of 27 <123 ... 252627>
GGDR
 Cheers, Greg
Post #684064 27th Jan 2024 9:54pm
mcspreader
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
I guess the Aliexpress link is specific to individuals as it works for me fine. Unfortunately their share options are limited to platforms I don't use I will look deeper but I think I just did a search for car seat cooler and the items were amongst the usual irrelevant junk the Aliexpress always spams you with. 2011c Vogue SE 4.4 Oil Burner
1991 Hilux 2.4d MkIII. Sadly goone due to space and time.
2008 Skoda Octavia Scout
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #684076 28th Jan 2024 3:43am
mcspreader
OK, try searching for TZ032461 or for car seat refrigeration peltier in Aliexpress. If you select one you will find it then provides links to even more.The best I found for delivered price was £25 and pence although I think VAT needs to be added at final checkout. 2011c Vogue SE 4.4 Oil Burner
2000 TVR Tuscan 4.0
Loads of crap. Gone
Post #684078 28th Jan 2024 4:54am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, has anyone tried one of these Aliexpress units for real ?
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684122 28th Jan 2024 5:03pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Yes I just replaced mine with one of these last week and works fine so far 🙂
I bought this one
https://a.aliexpress.com/_ExbIAQN 2011 Vogue SE 4.4 TDV8
Post #684124 28th Jan 2024 5:14pm
AndyRoo
Thanks for that. The guy who was repairing mine can't get the parts now so it's fallen through.
I'll get one of these and give it a go then,
Cheers Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684262 29th Jan 2024 9:41pm
Griffiths
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Barolo Black
Hi Tinfish,
Did you ever sort your problem with heated and cooled drivers seat ?
I've got a newly acquired 2011 Vogue SE with same problem.
I would appreciate any advise..
Post #685078 8th Feb 2024 1:41pm
AndyRoo
Hi, Peltier part just arraived, but the rest of the unit is still with the other "fixer", soon as I get that back I'll replace the peltier and hopefully all good.
Problem fixed for now though, swapped in the passengers unit, SWMBO noticed, embarressed to have been caught out, damn. Whistle Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685079 8th Feb 2024 1:46pm
kevinp
Just bit the bullet and bought the whole unit HHK500060.
Alot of money for a warm bum but I like things to work as they should !!!
Post #685545 13th Feb 2024 3:24pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
I ordered one of the alieexpress peltiers, took a couple of weeks to arrive and was about £32 all in, it seems to work , we'll just have to wait and see how long now , hopefully the OH will be happy as I only ever use the cooling but she likes the heater .
Post #686081 20th Feb 2024 5:51pm
RovingCanary
Was your ducting split and did you manage to fix? I have ordered a pettier too
Post #686084 20th Feb 2024 7:00pm
matthews
Ducting was fine and still soft and pliable , had car nearly 8 years now and only just got round to sorting seat heater (not a priority for me ), i'd had it apart a few years ago to check ducting when info was less readily available and peltiers were unavailable , thought for £30 rather than a few hundred it was worth a punt , just got to see how long it lasts for now , time will tell , back heats up a lot more than base so base one could probably do with changing too but i think they are a tad more awkward to get out .
Post #686101 20th Feb 2024 9:52pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
just a quick update on this, AliExpress Peltier unit fitted - fairly easy swap out. Cost around £32 and works a treat!
Happy to assist if anyone is thinking about doing it and unsure.
Chris
Post #688385 19th Mar 2024 8:49am
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Just stripped my drivers seat down & confirmed that the peltier is not working with only about 3 ohms of resistance. I too will get one ordered this week. I just have a small crack at the base of the ducting so will fix it with a little baking soda & super glue and the job will be a gooden.... 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #688519 20th Mar 2024 5:00pm
Mfcetin
I bought this one
Update on my fix:
Less than a year later the Peltier element from Aliexpress broke down. I had ordered two of them so I put in the new one and lets see how long this one will last.
Anyone knows if the Peltier element from Ukraine is any better than Chinese one?
I read that it is from a company called Klifex in Kiev but I am not sure if it was really manufactured in Ukraine or they are just resellers of the chinese ones Smile 2011 Vogue SE 4.4 TDV8
Post #697612 8th Aug 2024 12:03pm
