![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Here is the bad news
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
hi tinribs,
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
How did you get on with the repair ?
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 ![]() ![]() |
I've not done anything about it yet. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
If you have cooled seats as well as heated you have two extra control knobs, one each side the clock....all the way anti-clockwise and it cools....turn the other way, it heats.
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Drivers seat on pretty much full cooling....
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 ![]() ![]() ![]() |
I'd been following this thread with interest (& other similar threads elsewhere) with a view to fixing my seats. I've just bought my car, it has a 3 month warranty and the dealer is covering the faults it had pre-purchase (this being one of them). The problem being that he didn't want me to take it to a dealer to diagnose and fix them because he's underwriting the cost of the warranty himself. I'm not the type to make the job unnecessarily expensive - so I'm working through its issues myself (but I've spent well over a grand now & I've covered the labour myself - which seems wrong!?).
This is a closer pic:
Another:
This is the faulty part after it had been removed:
By the way, this is what my car was bleating about before it was fixed:
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 ![]() ![]() ![]() |
hi, both my front seats are not working, i will have a go myself but first want to ask how easy/hard is it to strip the back panel off to expose the back fan, thanks |
ST12AT Member Since: 06 Nov 2017 Location: Colchester Posts: 8 ![]() ![]() |
From reading this I think the cracked ducting is the same problem I have.
ST12AT, Id guess that the seat back is very *likely* to be the same fault / part required as mine given what you've said & your fault code (but for the other seat) is the same.
If that's misaligned, that could explain it. Essentially, you need to set eyes on it to be certain - as I did in my case. Fatfred, do you have access to a diagnostic tool of any kind? I would recommend seeing what codes its throwing relating to the seat-heating. If they're failing with the same codes as mine then that you could be having the same issue as myself. The fact that both are failing is odd and people will obviously suggest you check all the fuses etc - but my advice is to see what the diagnostic codes are, clear them off, recycle the ignition, start-it and take it for a test drive - if the seats work, drive it with heated seats on for longer & re-scan it. If they remain dead throughout - the codes it'll almost certainly generate - will be a good indicator as t where to start looking. Hope this helps... If you wee near-by, I'd offer to sun your car for you & try help. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3892 ![]() ![]() ![]() |
Did you have any trouble getting the part out, I taped mine up in a hurry so might not have done it properly as the damage was all at the back (out of sight) so before putting my hand in the wallet named "Range Rover" I might just whip the seat out again and remove the part to check more thoroughly. My symptoms are fan underneath the seat switches off after about 30 seconds, lights remain on and IIDTool comes up with the fluid leak fault, neither back nor base gets warm. Geoff |
Thats what mine did.
Ok, I've edited one of my pics to explain, top of the pic = top of the seat (I rotated the pic when I edited it so it's the right way up);
Red circles are the compression clips which just unclip & release the motor / cell. Blue circles are where the fabric clips on to a thin metal cross-member bar (these literally just unclip). Green circles are "plastic grub-push-friction-clip things" I poorly describe - the plastic friction screw that you literally just push-in / pull out (carefully). Obviously, the electrical connector to the left of the first red circle. Hope this helps! |
Thanks tl2k for the very prompt and clear reply. I think I'll have to wait until I can get someone to help me get the seat out it looks as though it is easier to work on. Geoff |
