Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 1 of 27 123 ... 252627>
tinribs
2010 Range Rover Vogue SE TDV8 Galway Green
Hello everyone!
Long time lurker (I'm usually over on Defender2 or Disco3).
Done a bit of a search and read a few threads, but nothing comes up for the facelifted L322's.
I've got a Vogue SE with the heated and cooled seats. Problem is, the drivers side one doesn't work. The switch illuminates and I can feel the motor come on for a few moments, but then the motor cuts out (switch stays illuminated).
I plugged a code reader in and got the following fault 'B1231 - Right Seat'.
The underside of the seat is completely different to pre 2010 cars it seems, so not really sure where to start.
Any help would be much appreciated!
Thanks.
Post #454928 22nd Oct 2017 3:23pm
Baltic Blue
We have only had one report of a 2010/2012 heated/cooled driver seat failure.
It was by Zeppfish. You could try sending him a PM to see if he can offer any help/ advice.
Cheers
Mike B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #454930 22nd Oct 2017 3:56pm
GGDR
Maybe start with the basics:
Try cleaning or replacing the filter. Might be clogged then it's shutting down to protect the motor.
It's a round disc - not sure if it's washable (only one way to find out right?). Comes off with a quarter turn.
You might be lucky.
Greg Cheers, Greg
Post #454933 22nd Oct 2017 4:44pm
MarkA
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
Will follow with interest as my drivers seat also doesn't heat, just assumed my fat arse was too heavy.
If you find any solutions please update the thread.
Post #454935 22nd Oct 2017 5:15pm
Baltic Blue
Tell everyone how many miles you have now sat in it !!! Mark.
Mike.
Post #454946 22nd Oct 2017 6:17pm
nino_nino
round filter is washable, i did my on both sides. Thumbs Up
Post #454957 22nd Oct 2017 7:28pm
mjdronfield
Filter? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #454981 22nd Oct 2017 10:05pm
nino_nino
mjdronfield,
same type of filter you have in house aircon.
it is twist and release.
Post #455012 23rd Oct 2017 9:44am
MarkA
Mike.
B.B.
It's at 220,000 but sat in airport parking having a rest for a couple of weeks.
Post #455014 23rd Oct 2017 9:59am
tinribs
Thanks chaps - I'll give the filter a clean this evening - hope it's that!
Post #455027 23rd Oct 2017 12:15pm
Zeppfish
Tinribs
As quoted mine failed with the same symptoms it turns out the unit uses a bit if electrical magic through a device called a peltier cell. In layman's terms if current travels through it one way, it gets hot, and if current travels the other way it gets cold!
JLR in their wisdom put a thermistor on the hot side of the unit, to stop a burned arse / seat, but no temperature control on the cold side. Sooo if its running cold but not hot, its the thermistor that is failing. If it does not run either hot or cold then it is probably something else with the fan unit being the first thing to check!
The other thing to note is that each seat has 2 units, one for the back, and one for the base! there is only a thermistor in the back unit, as this is the unit that runs all the time the heating / cooling is on!
Firstly run the seat cold, and see if it works indefinitely! if it does switch it over to hot. If it runs for a few seconds, and then the fan cuts out it is the thermistor i"m afraid and thats a new unit (the thermistor is bonded to the heating surface of the peltier cell)
My indie changed it out for a new one, and it now works fine! 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #455028 23rd Oct 2017 12:21pm
Zeppfish
For a bit of nerd speak about Peltier cells
https://en.wikipedia.org/wiki/Thermoelectric_cooling
Explains how they work without giving anyone too much of a head ache
Dan 2006 RR sport HSE
Post #455029 23rd Oct 2017 12:31pm
Baltic Blue
Wow , technology 👍👍👍
To think, I remember my dad repairing a puncture in the inflatable inner tube in the seat cushion of an old Wolsey he used to have.
Cheers. B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #455030 23rd Oct 2017 12:47pm
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
mine failed also, I removed it and found one of the solder joints failed on 12v feed from moisture it looks, just retouched with iron. It is called a module but simply is a fan and peltier coil, not really worth the $500, think was made by Lear.
Post #455051 23rd Oct 2017 5:44pm
tinribs
Thanks for your advice Zeppfish Thumbs Up - Results are as follows:
Firstly, the cooled option works fine and doesn't cut out, so I switched over to the heated option and it cuts out after a few moments - so it looks like it's the thermistor, which looking at your post means I need a peltier cell.
Do you (or anyone for that matter) know if it's DIY'able? If not, what sort of costs can I be expected to pay at an Indie?
Thanks again!
Post #455093 24th Oct 2017 12:07am
