![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Thanks for your reply - do you have a website to order from? |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Send me a PM and will be in touch tomorrow. |
@JNC
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Waking up the thread, hoping someone can help me diagnose exactly what has failed on my driver's heated/cooled seat.
If anyone needs a complete assembly - https://www.ebay.co.uk/itm/313963553273 Jaguar part number but visually the same as the LR one |
28capridave Member Since: 08 Nov 2020 Location: stockport Posts: 28 ![]() ![]() ![]() |
I first thought mine was the base peltier but it turned out to be the ducting in the seat backrest fitted a new one and back to fully working, a lot of your faults I also had so always worth checking the rear ducting first as its relatively easy to get too in comparision to the base unit which I had in and out like a yoyo |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Are these repair kits still available? I want to get on and fix the lack of cooling on my seat back. Base is OK so I suspect cracked ducting on the seat back one.... These? https://www.jnc-automotive.co.uk/product-p...repair-kit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Heater repearing.
lesteph Member Since: 23 May 2013 Location: CACHAN Posts: 1 ![]() ![]() ![]() |
Dear,
Roverte Member Since: 01 Dec 2021 Location: Connecticut Posts: 6 ![]() |
With the help of this thread I'm sure that I have a cracked plastic duct but I cannot get the seat disassembled to remove and inspect.
My post:
Thank you so much - that photo is exactly what I needed to be able to feel the tabs. |
DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 42 ![]() ![]() ![]() |
Can anyone verify where the control module is, or even better post a picture. I have a 2012 supercharged with no sign of life at the controls and an empty compartment with connectors under the passenger seat, in the plastic covered cubby. |
