Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 20 of 26 <123 ... 192021 ... 242526>
28capridave
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hi thanks for the reply the system shuts down if i dont turn the base off within about 5 secs
Post #617324 23rd Dec 2021 6:48am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Sounds like the base unit is detecting overtemperature.
Quite rare but seems to be happening more often lately.
Would advise changing the peltier cell in the base unit.
As this is seemingly happening more often, we will look into importing a batch of cells on their own. (We currently only do the set back as a kit pair)
Post #617350 23rd Dec 2021 10:49am
28capridave
Ok thanks for that, do you happen to know if the peltier units are the same back and base?
Post #617394 23rd Dec 2021 5:00pm
JNC
They are the same.
Ducting is different but the cell is the same.
Post #617420 24th Dec 2021 12:40am
28capridave
Thats great many thanks for your help.. Thumbs Up
Post #617477 24th Dec 2021 3:58pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Fixed my driver's seat heating/cooling today by replacing the seatback Peltier unit for a servicable spare from my old TDV8 spares pool (the gift that keeps on giving). My failed Peltier unit had a completely fractured duct, no wonder it wasn't working. If I've understood previous posts here, the broken duct causes the Peltier unit to overheat due to lack of airflow though it, and eventually fail.
Few more jobs on the list:
1. Fit new rear suspension airbags (slight loss of air from the rear, causes compressor to run for a bit on each start)
2. Change transfer case oil
3. Refurb old TDV8 spoiler brake light and swap with unit currently on the SC, which has a couple of failed LEDs.
fanders
Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #618908 5th Jan 2022 7:44pm
JNC
Exactly right.
Although we have seen an increase in the base cells dying.
Post #618917 5th Jan 2022 9:06pm
Giles
For Info: I have just replaced the Peltier Cell in my 11 plate TDV8 in the seat base. I managed to do it without removing the whole assembly from the seat base by just undoing the 4 mini torx screws and the cable ties and pulling the cell cover off. It was a fiddle but much easier than rmoving the seat cushion etc. It can be done!
The symptoms on my icarsoft v3 were a seat blower not working and on the reader the seat base temperature was 205C. When I removed the cell it was covered in a green gunk and clearly dead. I managed to get a replacement cell from ebay from a great guy called Jamie at JNC very reasonably. A very happy customer.
Post #619990 14th Jan 2022 9:57pm
JNC
Glad to hear you got it all sorted.
Post #619994 14th Jan 2022 10:06pm
Giles
Here’s what it looks like!
Post #620030 15th Jan 2022 10:29am
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
Fixed mine, this is how to do it Thumbs Up Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #623792 15th Feb 2022 3:25pm
fanders
Nice video, thanks for posting!
fanders Thumbs Up ---------------------------------------
2021 Hilux 2.4
Post #623901 16th Feb 2022 3:08pm
Bingo_123
guys, the passenger heated seat on my2010, is not working. Fuses look fine. I only have heated seats.
When i press the button , the light doesnt come on the circular button.
IIDTool gave the following error :
B1038-11 (2f) Front Left Seat Heater Sensor - General Electrical Failure - Circuit short to ground.
Tried to check the connector under the seat briefly, seems ok but will check in detail if i know where to look.
Please advise how to sort this out.
Thanks
Post #626914 24th Mar 2022 2:09pm
Phoenix
@jnc Are these repair kits still available?
Thanks.
Post #631901 16th May 2022 9:09pm
JNC
We are waiting on 2 orders to come in. Been waiting over 2 months for our first order.
Hoping they will arrive this week.
Post #631902 16th May 2022 9:17pm
