Home > Technical (L322) > Where did that cloud of smoke come from?
Page 8 of 13 <123 ... 789 ... 111213>
DrRob
Thanks Kev, agree Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588887 25th Mar 2021 3:10pm
GGDR
Rob just catching up here... that throttle body pipe does look very oily - on the outside. Leaking?
. Cheers, Greg
Post #588896 25th Mar 2021 3:46pm
DrRob
Could have been. Cleaned up and they might use some PTFE. It's going to a local mechanic tomorrow....we've got so far and I'm advising remotely!
Will keep posting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588899 25th Mar 2021 3:57pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Any report back from the local mechanic after they had taken a look? 2011 TDV8 Vogue SE
Post #589523 30th Mar 2021 9:16am
dennij
Time for an update from me.
I've finally got around to getting the DPF cleaned and whilst off I also removed and checked all the sensor flexible pipes for splits/cracks or blockages, which I'm pleased to say all passed. Now all I need is a combination of time off work mixed with good weather so that I can refit and then set the pressure sensor up as per the instructions in the WM. I tested the voltage readings prior to the DPF being removed (or flagging an Amber or Red warning) and they were all reading within tolerance. I will of course retest once the sensor has been reset just to check that they still remain OK.
Pictures of the DPF before and after
Before :
After :
 2011 TDV8 Vogue SE
Post #589562 30th Mar 2021 5:13pm
DrRob
Did you do a pressure test on that before removing it like Steve Norman ďid for James?
Fingers crossed Thumbs Up
Update soon from our escapades Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589572 30th Mar 2021 6:37pm
dennij
I haven’t had a pressure test on the cooling side if that’s what you mean. I have taken a note of the work James had carried out which caused me to monitor the coolant temperature with the IID which was reporting as correct, however, I still haven’t discounted that this may be an issue and is included in my ever growing list of testing to be carried out once the car is back together. Hopefully your friends vehicle will be a much simpler fix and if it points to the thermostat housing then I may as well change that too Thumbs Up 2011 TDV8 Vogue SE
Post #589574 30th Mar 2021 6:44pm
DrRob
We will report back soon....we wait until we have the full story to avoid lots of posts... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589624 31st Mar 2021 6:40am
DrRob
Changed 4 doughnut rubbers (old ones were fine) as good practice
Cleaned MAP in doughnut (very scuzzy)
Cleaned intercooler top hose to throttle body and the Boost Temperature sensor inside. Cleaned up green lip seal.
Engine coolant - coming up to temperature OK. No thermostat issues
Tested back pressure on DPF with a manual pressure gauge on front sensor. Pressure was 2psi
Changed oil due to high dilution figure and reset service interval using IID
Reset all parameters with mechanic's professional kit (don't ask me the name)
No forced regen carried out due to low back pressure
Told car is has a new DPF fitted
Light extinguished Thumbs Up
Not out of the woods yet so currently monitoring usual stuff via IID over next few days.
Plan to get a high pressure test done (not easy to find a place that does)
Post #589685 31st Mar 2021 2:06pm
dennij
Good update Rob, lots of familiarity in there for me. I've had to tell the car it's had a new DPF on 2 occasions now due a red light, it's not ideal but at least it gives you a chance. I guess the best thing to do now is run it around and watch how quickly the soot level rises and if a regen gets requested and more importantly, completed. 2011 TDV8 Vogue SE
Post #589690 31st Mar 2021 2:33pm
DrRob
Yes. My understanding is roughly 1g per 10miles.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589695 31st Mar 2021 2:50pm
Dolphinboy
Rob, just spoken to Steve Norman. He uses a normal (standard pressure gauge) to do a DPF pressure test using the front sensor tube. if it is 2PSI then it is fine. It will normally regen at around 29PSI/2 BAR, but in reality it will do one at 15 psi.
Hope that helps.
Post #589751 31st Mar 2021 7:02pm
DrRob
That’s exactly how it was tested with a Sealey pressure gauge on front sensor pipe via a temporary T piece
Thanks James Bow down
All good info coming in Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589754 31st Mar 2021 7:05pm
DrRob
So far, the work carried out above has cured the amber issue. Ongoing monitoring with IID.
Ona separate thread I’ve reported that Durham Remaps can remove EGR and DPF functionality for £595... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591650 18th Apr 2021 6:20pm
DrRob
dennij - any updates your end? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #596379 4th Jun 2021 7:19am
